Oil temps?
Old Jan 28, 2011 | 07:15 PM
haljensen's Avatar
haljensen
Default Oil temps?
I have an '08 A6 Z51 and am curious about my oil temps. They are within 2-3 degrees of coolant temp with city driving. Just checked again; coolant @ 214° and oil @ 212° after a 10 mile drive with one stop with 70° ambient temp..
The reason I'm asking is I just added engine cap covers in heavy aluminum and the oil fill cap gets too hot to touch in day to day city driving. The heavy aluminum seems to act like a heat sink.
Old Jan 28, 2011 | 07:33 PM
B y r o n's Avatar
B y r o n
I missed the question in your post. What do the caps have to do with the oil temperature? The caps get hot because they absorb the heat from the engine and air trapped under the hood.
Old Jan 29, 2011 | 09:16 AM
haljensen's Avatar
haljensen
The question is about other peoples oil temps. Are my nearly equal oil and coolant temps normal?
Old Jan 29, 2011 | 09:25 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes, and it's because with the z51 package your oil cooler is in your radiator.
Well...at least it is on the manual. Not sure about the auto z51.
But to answer your question mine run about the same too.
Old Jan 29, 2011 | 09:27 AM
B y r o n's Avatar
B y r o n
I haven't payed close enough attention to mine to say for certain but hazard a guess and say yes and here is why. The radiator/coolant main function is cooling the engine. Temperatures stabilize based on conditions. Oil circulates through the engine and also picks up engine heat. The temperature sending units are located in different locations so there will be differences but probably not much.
Old Jan 29, 2011 | 09:32 AM
Boomer111's Avatar
Boomer111
Oil temp seems in line with what I would see. I have the 160 degree stat. so I would not see anything over 195 coolant temp. with your scenario. On the open road the coolant would come down to 180 with the oil staying about the same as before 210ish.
Old Jan 29, 2011 | 10:32 AM
Ragtop 99's Avatar
Ragtop 99
160 stat with a Z51 here. depending on the air temps, oil is about 10* - 25* hotter than water. In the winter the oil stays cooler; summer the oil heats up more and gap widens.
Old Jan 29, 2011 | 03:35 PM
LEAVINU's Avatar
LEAVINU
This does not sound normal to me fellas. For me to see 21x temps it has to be 90+deg and stop-n-go traffic for 10mins plus with the a/c on. The OP said he stopped once in 10miles during 70deg weather. There is no reason he should see that high over 200deg in those conditions. I don't even see mid 190's under those conditions.
And yes the oil temps generally are within a couple of deg of the coolant temps under that type of driving.
Old Jan 29, 2011 | 04:36 PM
ROC OUT's Avatar
ROC OUT
Hal, I tend to agree with this post above. As I recall, driving around Austin in 70 degree temperature would only produce coolant temperatures around 205 with oil around 212 or 214 (in my '07 MN6). That said, I don't really know if the differences you are experiencing are a problem. I would go drive now to confirm but I am recovering from a stomach virus.
Let us know if this ends up being a problem.
Old Jan 29, 2011 | 11:16 PM
Dirk Miller's Avatar
Dirk Miller
Default your temps are fine
The hot engine light for oil will come on at 318 degrees F.
Old Jan 30, 2011 | 12:48 AM
1Corvette's Avatar
1Corvette
The oil inside your engine serves two purposes. 1) To lubricate the internal components of the engine 2) To cool the engine and it's components. I agree that your oil seems to heat up a bit more quickly than normal, but I would not worry about it. If you had your oil changed and did not complete the work yourself, are you sure you got the recommended synthetic oil and viscosity? Both could affect oil temperature. Overall, your engine oil temperature should run within 15 ~ 20 degrees of your coolant temperature once the engine has been at operating temperature for 30 minutes or so. Of course, driving conditions will have more influence than anything. Are you just driving in town, long road trips at a steady speed, or racing? I would not expect the heavy aluminum covers to have any effect on oil temperature.
Old Jan 30, 2011 | 01:50 AM
Bill Dearborn's Avatar
Bill Dearborn
There is nothing wrong with your engine oil or coolant temps. Those readings can be perfectly normal. Your oil temp could be that level especially since the coolant temp is at 214. How hard were you running the engine just before you took the temp readings? As you run the engine harder (more power) or run it easy at high revs (buzzing the engine) the oil temp will climb. With the EOC in your car if you were tracking it and running at WOT for 20 minutes or more your oil temp would climb to about 260 with coolant temps running over 220.
Bill
Old Feb 1, 2011 | 10:24 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Cruising along the interstate on a mild day after everything is warmed up, my 2009 A6 Z51 will have coolant at 196-200, and oil at 210-220. Hot day, oil goes to 225 but coolant stays the same.
Driving moderately in traffic, coolant will get warmer but oil changes very little.
2008 & later A6 do not have an oil cooler, not sure about earlier.
To Oil temps?
