Fluid change?
Old Feb 9, 2011 | 12:31 AM
Le Mans Z06's Avatar
Le Mans Z06
Default Fluid change?
My car is in the shop getting Corsa Sport mufflers being put on, while it is there I was thinking of maybe changing some fluids. The car has 32k miles on it, and I bought it used with 27k miles. At the end of October I was at ECS to get longtube headers put on with a SC600 kit of theirs + methanol. What fluids should be changed? I don't know what (If at all) the previous owner may have had changed.
The regular motor oil is fine, it was changed with the S/C oil a few weeks back before snow and then the car just sat. I doesn't get driven a lot, just on the weekends weather permitting. As of now it hasn't been raced, waiting for drag radials once the weather clears up for good come spring.
I was thinking trans kit + flush, and the rearend fluid? Should I bother with flushing the brake fluid, or coolant? Any feedback would be great, I would need to know by 10 am or so tomorrow if I decide to get it done while it's in the shop. Thanks!
Old Feb 9, 2011 | 12:55 AM
Daredevil95's Avatar
Daredevil95
I would do the tranny, rearend and coolant. You could go longer....50K but, if your like me you want to make sure everything is in good order. I do maintenance in stages....a little now a little later. As far as the brake fluid goes I would wait until after 50K or when you replace the rear brakes. Good luck
Old Feb 9, 2011 | 07:43 AM
smurfkiller's Avatar
smurfkiller
i would change all those plus especially clutch fluid if you have it. then at least you know when it was changed and what it was changed to.
Old Feb 9, 2011 | 09:18 AM
NYC6's Avatar
NYC6
Brake fluid would be my priority. BF is hygroscopic(absorbes moisture) and 4+ years is long enough. I would drain and refill. A Tech II machine should be used to fully extract all the old fluid.
To Fluid change?
