Does anyone sell a complete kit to convert an 2008 wet sump LS3 to the LS9 dry sump system. If not, where can I find a a part number list of all the required components?
Thanks!
The parts already exist at the chev dealer since 2010 Gs 6spds come with a dry sump installed.Ask Gene at the gm parts house.
z51vett
Its not going to be very cost effective to do this. The external parts such as the dry sump tank and lines are easy enough to install. But the LS3, LS9 and the LS7 dry sump engines all have a 1" longer crank shaft snout so that it can use the special oil pump that makes it all work. That means that you would either have to remove the engine to install the correct crank, oil pump, front cover and oil pan to make it all work or swap the engine out for a dry sump equipped LS3, or LS7 engine.
With a blower there is no room up top. You would have to use the style that will mount in the place you remove your AC compressor. That is the best system but mine is mostly street driven abd I cant give up ac in Florida
ill take a look at where there is room to mount the pump, you could expand your market by making a bolt on kit for sc cars
