Ls2 engine oil low?
Old Mar 3, 2011 | 02:28 AM
operationblackwater's Avatar
operationblackwater
Default Ls2 engine oil low?
Does anyone have any infoor suggestions on why my ls2 engine is consuming engine oil and where does the oil go?
The "check engine oil" message comes up and the oil level is about .5 quart low about every 500 miles
There are no symptoms of mechanical failure either. Engine runs smooth and strong
Old Mar 3, 2011 | 02:31 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Originally Posted by operationblackwater
Does anyone have any info on why ls2 engines consume Excess engine oil and where does the oil go?
Not sure what you're referring to here. Your LS2? Are there others? I haven't seen this info on thsi site, perhaps I missed it.
Mine uses no oil between 5K mile oil changes, now at 50,000 miles.
Old Mar 3, 2011 | 02:39 AM
operationblackwater
I was referring to an ls2 on my 07. My 2011 doesn't have that issue. It's not burning oil nor leaking anywhere. Exhaust pipes are clean. I just don't know where the oil is goin to and why
Old Mar 3, 2011 | 06:19 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
You'd have to be over a quart low to get that message. I would check the sensor; it is located right by the starter on the passenger side of the car.
To Ls2 engine oil low?
