dyno numbers!
Old Mar 12, 2011 | 12:44 PM
kboboz71's Avatar
kboboz71
Default dyno numbers!
Well I made it to east texas muscle cars to get a baseline on my setup yest. eve. And by the way Stephen and the guys over there are real nice guys and have a great knowledge of these cars.. ok so to the Dyno results. The first pull only showed 484/414. So we knew something was wrong for the tq numbers to be so low so we started looking at things and stephen found that the pos vararam lid had collapsed and was just dangling there. So we put it back in and tightened as well as we could and made another pull. This time it made 495/450! And this was with a 12.1 a/f ratio. So its got some left with leaning it some. Not too bad I guess. What do y'all think
Old Mar 12, 2011 | 12:50 PM
epic's Avatar
epic
Good power, but you forgot to tell us your mods.
Old Mar 12, 2011 | 12:57 PM
kboboz71's Avatar
kboboz71
They are in my sig. But here ya go..
06 c6 z51
afr 205's, milled .040, arp head bolts, pinned crank
custom grind cam 231 239 644 651 114 +2
fast 90mm intake unported
stock ported throttle body
vararam ram air
kooks 1 7/8 long tubes, kooks 3in. mid, npp mild to wild
exedy twin disk
mgw shifter
z06 output shaft, z06 small shafts in diff, 3.73's
pfadt coilovers
Old Mar 12, 2011 | 01:09 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
Stephen@ETMC is awesome.
With some fine tuning I'm sure you'll hit 500rwhp
Old Mar 12, 2011 | 01:12 PM
kboboz71's Avatar
kboboz71
Yeah it needs a little bit of work. Its getting a ported fast 102 this week so im shooting for well over 500.
Old Mar 12, 2011 | 01:14 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Nice numbers. Are these numbers with the new lethal ported 102mm fast intake?
Old Mar 12, 2011 | 01:19 PM
kboboz71's Avatar
kboboz71
No this is with the stock fast 90
Old Mar 12, 2011 | 01:57 PM
1FSTVET's Avatar
1FSTVET
The ls2 reacts well to the fast 102 should be some nice gains. I have one on my ls2.
Old Mar 12, 2011 | 02:05 PM
kboboz71's Avatar
kboboz71
Hey did u get to Dyno yours after the 1.8 install?
Old Mar 12, 2011 | 03:19 PM
SpinMonster's Avatar
SpinMonster
That cam looks like a winner.
With .65x and .64x lift, I'll guess the intake lobe is a 235 lsk WITH A .646" lift making it a 4 degree or less, split. Nothing under 235 duration has a lift over .63x. Assuming a 239 exhaust puts overlap at about 11 degrees. Its a pretty agressive cam and looks interesting.
Can you post the dyno sheet?
Old Mar 12, 2011 | 03:24 PM
kboboz71's Avatar
kboboz71
Yes the lift is 644/651. And I've got a pic of the Dyno sheet on my phone but how would I get it on here?
Old Mar 12, 2011 | 03:26 PM
SpinMonster
E-mail it to me and I'll post it for you.
Detentionizover@yahoo.com
Old Mar 12, 2011 | 04:04 PM
JayplaySS2's Avatar
JayplaySS2
Very nice, who spec'd that cam? What length pushrods and what rockers are you running?
Old Mar 12, 2011 | 04:18 PM
kboboz71's Avatar
kboboz71
Email sent.
Old Mar 12, 2011 | 04:27 PM
kboboz71's Avatar
kboboz71
Specd by gil navarez. Pushrods are 7.40 I believe. Stock rockers. Upgrading the trunions next week.
Old Mar 12, 2011 | 05:23 PM
kboboz71's Avatar
kboboz71
Did u get the sheet spin?
Old Mar 12, 2011 | 10:22 PM
JayplaySS2's Avatar
JayplaySS2
Thank you sir
To dyno numbers!
Old Mar 12, 2011 | 11:14 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Do yourself and your valve train a favor and install full roller rockers. The lift is way over what the stock rocker arms were designed to take.
Old Mar 13, 2011 | 12:03 PM
LEAVINU's Avatar
LEAVINU
What else are you doing power wise at the same time as the 102? Very interested in seeing the gains of a ported 102.
Old Mar 13, 2011 | 12:41 PM
kboboz71's Avatar
kboboz71
Im not changing anything before we make a pull with the 102 on it. That way we can see exactly what I gain from just the intake
