Tune for E85
Old Mar 29, 2011 | 04:40 PM
KB9GKC's Avatar
KB9GKC
Originally Posted by IsuckBad45
Alright guys he put the Bone stock vette on the dyno with E85 as the only mod. Results bellow.
Stock LS3 manual - 375whp (91 octane)
Stock LS3 manual w/ E85 - 420whp
A 45 WHP gain over low grade premium. Pretty good if you ask me.
Graphs are on the way!
Hello,
Do you have a graph to display the A/F ratio?
Douglas in Green Bay
Old Mar 29, 2011 | 05:30 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
Originally Posted by KB9GKC
Hello,
I dont think my tunner will be giving this up. I will ask though
Old Mar 29, 2011 | 07:55 PM
Mr.Big's Avatar
Mr.Big
I've run E-85 for 8 months now and can't say enough about it... It's the best of all worlds, and, as already stated, works VERY well in F.I. applications, although it works well in N/A applications as well. Though to truly take advantage of E-85 in an N/A setup you should bump the compression up. 13:1 seems to be the sweet spot on LS N/A applications running E-85...
Old Mar 29, 2011 | 08:26 PM
wmckeenster's Avatar
wmckeenster
Don't you have to upgrade the fuel pump/system as well as injectors when switching over to E85 on a C6Z06 (LS7)?
Old Mar 29, 2011 | 08:34 PM
trophystock's Avatar
trophystock
Our shop car makes 500 with a bone stock 08 Z06, but we are at the limit for pump and/or injectors.
Old Mar 29, 2011 | 10:59 PM
MikeSVT04's Avatar
MikeSVT04
So if I go to my tuner and say I want to run E85 all I have to do is dump E85 in the tank and tune it.....
So if I put a full exhaust and intake on I can tune it with e85 and be around 450 460rwhp..with my stock injector ls3....It sounds to good to be true.
Old Mar 29, 2011 | 11:01 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
lol,, why dyno'd to only 6k? run out of injector?
Old Mar 29, 2011 | 11:24 PM
res0n0xg's Avatar
res0n0xg
Clearly you got great gains, however I'm curious as to the gains on a car like mine...
I'm already tuned well for 93oct with full exhaust, and CAI. I make in the 420's rwhp, for the change to be worth it to me I'd want to see at least a 20rwhp gain across the RPM range, too bad so few have done this.
It would be completely sick to have just a full exhaust car making 440+ to the rear wheels.
Old Mar 30, 2011 | 05:23 AM
trophystock
Every NA car I have done has made around 3% more power with just E85. It has to do with the amount of BTUs you burn, E85 has less BTUs then gasoline but you use allot more of it hence the power gains.
Old Mar 30, 2011 | 10:44 AM
LT1_E85_Corvette
Well it seems that the factory fuel system can handle up to 500whp on e85 when looking at the 08 ZO6 (same fuel system as LS3). With full exhaust and intake I bet you would be close if not over 440whp. The fact is, this is real and none of these older corvette guys are even thinking to look this way.
The turbo market is all over e85 and it's actually better for your car (cheap race gas). I'm getting ready to tune my factory NPP LS3 MN6 car and will expect over 420whp BONE STOCK.
If anyone wants to do this let me know as my tuner can get the job done.
Old Mar 30, 2011 | 11:15 AM
SpinMonster's Avatar
SpinMonster
All you have to do is change the stoic value to 9.76 on one table.
You then tune the car as any other.
FI cars run a magnafuel pump good to 2000hp (1300 on E85) and appropriate injectors.
My pump:
http://www.jegs.com/i/Magnafuel/665/MP-4303/10002/-1
Old Mar 30, 2011 | 11:26 AM
robz's Avatar
robz
Assume 30% more fuel. It's simple math. If your Injectors and Fuel pump can support that with alittle to spare than you can dump it in and tune it; of course taking note of the stoichiometric values.
Old Apr 6, 2011 | 11:18 AM
  #33
eric04's Avatar
eric04
Old Jun 9, 2011 | 03:46 PM
  #34
LT1_E85_Corvette
Has anyone recently done anything with E85? My tune should be here today or tomorrow
Old Jun 22, 2011 | 06:12 AM
  #35
iDoLiZeDbyALL's Avatar
iDoLiZeDbyALL
You getting an email tune from this guy? Curious to see how this works out down the road for you before I do it!
Old Jun 22, 2011 | 10:21 AM
  #36
LT1_E85_Corvette
The tune has been completed and everything is being tracked on another thread. Search for "my E85 experience". A lot of really awesome data there.
Old Jan 31, 2015 | 06:18 PM
  #37
Whis9's Avatar
Whis9
Any issues running E85 without tune? I ask because I will have to fill tank with E85 and drive to tuner to have it tuned. Plus I want to get all of the 93 cycled out
Thanks for the help
To Tune for E85
Old Jan 31, 2015 | 06:38 PM
  #38
djfury05's Avatar
djfury05
Thanks for the help
Could you possibly bump more threads about E85 today that are 4 years old ??
Old Apr 22, 2017 | 03:59 PM
  #39
2L8LUZ's Avatar
2L8LUZ
Nobody's has mentioned the biggest GAIN from running E85 on N/A cars...
Its the sever COOLING effect for people like us in hot states like AZ and Nevada....
Bottom line you can beat the summer heat if you wanted too...unless you have special powers and weather controlling mind tricks that would put you on the next TOSH.O episode...
The gains shown above are nice.... However you cant put a price on having winter weather driving to an extent during the summer months...
MPG or whatever issue people want to debut here is pointless when you factor in the heat dissipation and having less performance driving during mind blowing heat that takes away from the driving experience!
Old Apr 22, 2017 | 11:09 PM
  #40
russ472's Avatar
russ472
my car runs MAYBE 5 degrees cooler, but E85 does absolutely nothing for IAT. #1 reason I continue to run meth.
