Tune for E85
Old Apr 23, 2017 | 12:32 PM
  #41
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Ethanol evaporating cools down a lot more than gasoline, so I guess you could say "cylinder" air temp would be lower on E85 vs. gasoline. And it's pretty tough to get E85 to knock regardless so IMO IAT doesn't matter as much on E85
I still run meth on mine on top of E85 since it was already on there and helps cool things down even more. Some of the crazy guys on yellowbullet run no intercooler + E85 with insane IAT's and power and their motors survive like that
Basically this:
http://www.modularfords.com/threads/...=1#post1858133
Old Apr 23, 2017 | 12:46 PM
  #42
xBoostx's Avatar
xBoostx
My heads and cam ls3 on e85 runs about 10 degrees hotter on gas.
Old Apr 24, 2017 | 08:16 AM
  #43
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Same, about 10* cooler on mine w/E85
Old Apr 24, 2017 | 08:46 AM
  #44
Suns_PSD's Avatar
Suns_PSD
Do the E85 Tunes not pull timing when the intake air temperature goes over 86 degrees like it would on gasoline? Do I get to keep more horsepower on E 85 come summertime? Cause naturally aspirated engines slow down quite a bit on 105 degree days when stuck in traffic.
Old Apr 24, 2017 | 08:50 AM
  #45
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You won't have to pull any until a whole lot higher than that on E85. I know people running turbo setups on stock LS3's without meth not pulling anything until 140+
NA setup should be fine to leave timing alone at higher IAT's
Obviously depends on the details, it's good fuel but an idiot tuner is still an idiot tuner.
Old Apr 24, 2017 | 11:36 AM
  #46
Unreal's Avatar
Unreal
Depends on tuner. Hell even on 91 I don't pull timing until 110+. Most tuners adjust those tables no matter what gas is used.
Old Apr 24, 2017 | 01:25 PM
  #47
Suns_PSD's Avatar
Suns_PSD
I'd be curious what Dave Steck, who tuned my car flexfuel, could tell us about this and more specifically about my car.
I've moved away from utilizing the E85 during the winter because with road temps I just have no traction. But I intend to run it full time now that TX summer is arriving.
Old Apr 25, 2017 | 08:23 AM
  #48
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I am curious as well
