Tune + Calloway CAI + 160 stat
Old Apr 6, 2011 | 02:48 PM
  #41
KneeDragr's Avatar
KneeDragr
Originally Posted by TKOGTO
You are the 2nd or 3rd to make the observation that initial #s seem low. What should I have expected?
I've been told that @ the wheels in an A6, I should see ~20% reduction in HP vs the OEM stated #s @ the crank. 20% off 436hp = ~349 and mine came in at 352hp.
Is 20% loss @ the wheels too much in an auto?
Its 10-15% depending on the type of dyno. So they usually make around 370 on 1 type, and 390 on the other.
Old Apr 6, 2011 | 02:52 PM
  #42
FloydSummerOf68's Avatar
FloydSummerOf68
Again, we have no idea what he was actually losing at the wheels because no SAE corrected numbers were provided.
The numbers provided for before and after were uncorrected.
It's impossible to make any assumptions off of that data. Uncorrected RWHP could've been low due to heat, humidity, altitude, etc...
Old Apr 6, 2011 | 02:54 PM
  #43
LS1LT1's Avatar
LS1LT1
Historically speaking, LS3 automatics have dyno'd up to 380rwhp on a Dynojet with the average being roughly 370-375.
Factoring in the extra weight of the GS rims and brakes along with the 2.73 gears might steal 5-8rwhp from those numbers versus a base model LS3 automatic with 2.56 gears...so your baseline numbers might not be quite as far off as we think.
But umm, your after numbers certainly are LOL.
We need to see the dyno numbers for some other A6 Grand Sports.
Old Apr 6, 2011 | 03:06 PM
  #44
TKOGTO's Avatar
TKOGTO
Originally Posted by KneeDragr
Either your tuner got your dyno sheets mixed up with someone who got a cam or intake installed, or he is outright lying to you and fabricating dyno's in order to win future business from you.
Sorry but those numbers are just a fantasy, your car is not making that much power.
Mixing up the sheets is something I hadn't thought of. I have to go back for some other mods so I will use that opportunity to check on this. Tuner is a friend of a friend so even if I thought your 2nd scenario was likely, I would probably let it go. Tune was less than 5 bills. At that price, don't need to open that can of worms.
Good news is that the car feels great, whatever the actual output. Not sure if this is as a result of driving a Volvo S60 all winter while the 'Vette was in storage or the actual gains. Either way, I am not overly concerned with the apparent unlikeliness of the dyno results. I was looking more for an education on tuning than trying to have the baddest hot rod.
Old Apr 6, 2011 | 03:10 PM
  #45
KneeDragr's Avatar
KneeDragr
The cool thing about the A6 tune is that it can change the shifting tendencies which are setup for fuel economy from the factory. So it will tend to feel even more impressive than the changes to the engine power would normally produce.
You hear people who get Chuck Cow tunes on their A6 say its like a whole new car.
Old Apr 6, 2011 | 04:41 PM
  #46
C7/Z06 Man's Avatar
C7/Z06 Man
Will it be going to the track now? For some real world numbers that will show the results you got for all your effort.
Old Apr 6, 2011 | 04:59 PM
  #47
TKOGTO's Avatar
TKOGTO
April 18th @ Lime Rock
