xm antenna location
Old Apr 5, 2011 | 11:40 PM
kaveman59's Avatar
kaveman59
Cruising
Default xm antenna location
Does anyone know the exact location of the OEM xm antenna on a 2007 C6 Coupe? I'm getting a no signal when I try and tune to a station.
Any help is appreciated.
Chuc
Old Apr 5, 2011 | 11:51 PM
BEZ06's Avatar
BEZ06
Exterior rear view mirrors.
Bob
Old Apr 6, 2011 | 12:34 AM
Vette_DD's Avatar
Vette_DD
Bob
Yep. 2005s had the antenna in a wart on top of the car, but all model years since then have the antenna in the outside mirrors.
kaveman, are you sure your subscription is current?
Is it only the XM band that you get no signal?
And lastly, do you have the Nav in your car?
Old Apr 6, 2011 | 01:06 AM
kaveman59's Avatar
kaveman59
Cruising
Thanks for your reply, I have Nav installed and GPS works fine. Also FM and AM radio works. I'm thinking I had some touch up paint on the Drivers door last fall and the body shop could have taken the mirror off. If I remember correctly the last time xm was working correctly.
Old Apr 12, 2011 | 11:33 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Is the GPS antenna also in the mirrors?
I just got my car back from a complete repaint (mirrors were removed and reinstalled) and I've no XM nor GPS signal
EDIT: I have GPS signal just not XM.. Body shop swears they reconnected everything in ext. mirrors... Oh well, back to 'em I guess
Old Apr 12, 2011 | 09:00 PM
kaveman59's Avatar
kaveman59
Cruising
Default XM working again
I don't know about the GPS antenna, but I took my car back to the body shop who did the touch up paint on my drivers side door last fall. They removed the interior door panel and reconnected a wire connector and behold, my XM radio was working again. Imagine that!
Chuck
Old Apr 13, 2011 | 01:48 PM
KenHorse's Avatar
KenHorse
Chuck
Was it a separate wire from the mirror harness or what?
To xm antenna location
