LS3 IM porting
Old Jun 7, 2011 | 07:54 PM
tomiboy's Avatar
tomiboy
8 rwhp and 10 rwTQ
Old Jun 7, 2011 | 07:55 PM
c6_rob's Avatar
c6_rob
Could you guys post pics of the tool you used?
What did you use to reach the back? I was thinking id have to weld a sleeved extension on to one of mine.
Old Jun 7, 2011 | 08:07 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Originally Posted by theofel
It definetly holds heat in. It was put there in 08 on the LS3 to quiet the valve train noise. I removed mine and I did not here any difference in the noise level.
Same here no more noise without it. Only thing is the Fuel rail covers look funny without the center cover so I left them off too
Old Jun 7, 2011 | 08:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When I port, I use these tools:
Professional dremmel Motor base with a flexable shaft cable
Regular dremmel tool for small work
Air Motor with cartridge rolls and burs
and this for the port entry work:
BC
Old Jun 8, 2011 | 02:57 PM
c6_rob's Avatar
c6_rob
Heres what I was thinking of using, do you think it will do the trick? Im going to weld some extensions on the sanding drums.
The lighter is for shank reference on the burring tools.
Old Jun 8, 2011 | 05:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The cartridge rolls will work fine but those metal burrs will dig and gouge way too much!!
Unless your EXTREMELY skilled using those burrs, your plastic manifold will NOT be happy!!!
BC
Old Jun 8, 2011 | 10:50 PM
c6_rob's Avatar
c6_rob
BC
Ok, thanks for the advice, Ill stick to the rolls.
Are you guys using extended shafts to reach the back of the main inlet ?(not the runners)
The only way I can think of getting back there is to weld extensions
Old Jun 9, 2011 | 02:05 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Rob
Don't get me wrong.. If theres something that needs to be removed or a LOT of material removed quickly,,,,,, those burrs work fantastic. Just don't use them to do fine port work!! I do use them but NOT for port shaping or fine trim work
Something that people don't consider,, sometimes you have to use an EPOXY (I use JB Weld) to build up stuff so that you can properly contour it to maximize the shape to enhance air flow...
Become a molecule of air.. Work your way thru the manifold. if you BUMP into something,,,,,,, it needs to be removed OR modified to ENHANCE air flow!
Plain and simple
BC
BC
Old Jun 9, 2011 | 02:11 PM
c6_rob's Avatar
c6_rob
Thanks for the advice Bill!!!
