Spark Plug
Old Apr 15, 2011 | 11:08 PM
juyanith's Avatar
juyanith
Default Spark Plug
My '07 Z06 has about 52k miles and I've been working on the tune for the past couple of weeks. It occurred to me that I should check the spark plugs as I have no idea what the previous owners may have done. Anyway, I pulled one and it looks pretty fouled, but that doesn't surprise me as I had just spent about 30 minutes at idle doing some logging earlier in the afternoon. I know the iridium plugs are supposed to be good for 100k miles but do you think I should replace them? I also noticed the plug wires are made by MSD. I don't think I'm having any particular issue with them but I've read some folks had problems and went back to the stock wires. Below is a picture of the plug, although it's hard to get a good photograph.
Old Apr 15, 2011 | 11:28 PM
starr719's Avatar
starr719
Old Apr 16, 2011 | 01:12 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Cannot tell from that picture. However, a spark plug on a modern car should not foul in 30 minutes of idling, even 300.
Old Apr 16, 2011 | 04:26 AM
Mike's LS3's Avatar
Mike's LS3
Tune the car properly, then change the plugs.
Old Apr 16, 2011 | 09:00 AM
REVAK's Avatar
REVAK
The plug looks like you may be running rich @ wot. Also you may want to concider the ngk tr6 plug. It's copper, runs cooler, allows for more timing without K/R , only down side is they have to be replaced more often. I had 30K miles on a set of iridium ngk plugs and was surprised at how much wear they had. [ gap had increased .010" ]. No way they would have gone 100k miles. I can run about 2* more timing without knock using the TR6's.
Old Apr 16, 2011 | 11:45 AM
Gering's Avatar
Gering
Tolero Apto Victum
I have Brisk spark plugs & MSD wires with no problems. If it were me I would just change the plugs and not think about it again.
Old Apr 21, 2011 | 09:35 PM
juyanith's Avatar
juyanith
I just replaced the plugs and for what it's worth they all looked a bit better than what I saw in the original picture. They were still black around the base but the tip was a lighter tan color. Of course, they have been run normally for a few days since the original picture. I do think the car was running rich at WOT before I started retuning.
Old Apr 21, 2011 | 09:55 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
Looks like a spark plug with 50k. I'm sure it was fine though but you did no harm by changing plugs.
Old Apr 30, 2011 | 12:38 AM
HDDP's Avatar
HDDP
While you're at it, you may as well "index your spark plugs" and "side gap" them a bit as well... you should notice a difference... I've seen 6 hp increases just from these small "racer tweaks".
Old Apr 30, 2011 | 01:07 AM
LS1LT1's Avatar
LS1LT1
Yes.
I wouldn't run any spark plug more than 30k miles (Iridium or otherwise), nevermind a full 100k.
In a stock/near stock and most NA applications, I would only use the OEM stock GM/AC Delco plugs wires...or new replacements of the very same if the originals are getting older/higher miles.
Old Apr 30, 2011 | 04:45 AM
MN Mark's Avatar
MN Mark
Cruising
How do you index the plugs and what is side gapping?? Thanks
Old Apr 30, 2011 | 10:26 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
People having issues with MSD wires is a user error.. most common is not getting the plug wire on all the way. The MSD and NGK combo is one of the very best..... MSD wires typically see less than 40 ohms resistance where most others are 300 plus including gm wires
You can run either or plug in there... the copper based don't last as long so it comes down to maintenance interval and what you want.
The iridiums last longer...
Old Apr 30, 2011 | 11:40 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
I'll repeat the question 'cause I would like to know, also:
" What is 'side-gapping' " ?
Old Apr 30, 2011 | 05:57 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I'd like to know too. I am running NGK TR6's and simply gapped them in the normal fashion at .037 per my tuner's recommendation.
Old May 1, 2011 | 03:44 AM
BSSN's Avatar
BSSN
I checked the iridium plugs in my 01 ws6 at about 75k miles. Gap was dead on oem spec. Car got 27.5 mpg doing 75-80 and was epa rated at 28. left them in and never changed them. At 150k miles it still ran great, got 21mpg city and highway, and was a dead even race for every new camaro ss I ran. At 100k miles I bogged and granny shifted it to a 14.0@102 with a 2.35 60'.
I'm a fan of GM oem plugs.
Old May 1, 2011 | 01:49 PM
HuskerBullet's Avatar
HuskerBullet
I use the Iridium plugs and love 'em. I know about indexing plugs, but I have to admit I've never heard of "side-gapping". I also use the MSD wires, too.
Old May 1, 2011 | 03:51 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Same wires that I have, and my NGK's are the platinums. I have no complaints whatever.
To Spark Plug
Old May 1, 2011 | 04:40 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Is the passenger's side front plug? This one gets much of the oil from the PVC system. Check another.
Old May 1, 2011 | 07:27 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Side gapping and indexing our sparking pins, what is this, the 70's?
Nothing more than crutches for poor chamber/bowl designs.
Side gapping is nothing more than trimming back the ground strap so that it aligns with the electrode. The thought was that it provided an unobstructed path for the flame kernel. Champion actually marketed plugs designed like this back when.
There is very little if any gains to be made doing either of these with todays head designs.
And your plug is fouled from being too rich, based on the picture, ie. flat dry black, I don't see shiny wet black.
Old May 1, 2011 | 08:20 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
The OP's plug looked fouled. This is what the plugs looked like when I removed them at 99,500 miles compared to the new one:
Plug order is from right to left is front of engine to back of engine.
Passenger side:
Driver side:
