Small Bore LS7 Heads - Available Now..
Old Apr 29, 2011 | 01:33 AM
HC Mechanic's Avatar
HC Mechanic
Originally Posted by C_Williams@RPM
...as soon as I get a candidate or get some spare time...
Old Apr 29, 2011 | 08:39 AM
JayplaySS2's Avatar
JayplaySS2
Any idea of an optimum M6 cam for the LS7 heads on a 6.0L yet? I'm not sure how much testing you've completed so far.
Old Apr 29, 2011 | 10:12 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
A few factors to consider, headers, Static Compression (more to the point the Dynamic Compression Ratio)...but for a 6.0 liter here's what I'd build or recommend.
SCR 11.2-11.5 (DCR=8.6-8.9)
1 7/8" headers x 28-32 long primaries and a merge collector
4.10:1 gears
...cam mildest for this - 234 / 242 @.050 .644 / .652 - 113+3 - great all around from 3,500-7,200 RPM - big lope, pretty good street manners - but I'd stay out of So Cal bumper-to-bumper 405 traffic.
...cam wildest - - 242 / 248 @.050 .656 / .666 - 114+2 - serious street and drag race 4,000-7,500 RPM - nasty sounding, great to cruise the boulevards and race - but otherwise...
Old Apr 29, 2011 | 11:33 AM
JayplaySS2's Avatar
JayplaySS2
4.10:1 gears
You read my mind. I just ordered a 234 / 242 cam (Pat G) on EPS lobes on a 112+2 (IIRC) so that sounds like a decent combo after a few other bills are paid. This means I would have to sell my catherdal FAST 102 but I'm sure that would be a breeze.
Thank you-
Old Apr 29, 2011 | 11:40 AM
0C_Williams@RPM
Former Vendor
Thank you-
call me when you are ready to order - it will take 4-5 working days on CNC, Valves,etc. -
Notes:
I'll do some prelim setup on how these stack up on p/v clearance - they will be much more friendlier in this regard, compared to LS3, because these have the 12º valve angle
You can sell the Fast and buy a factory LS7 manifold - you will probably make some money in the exchange
Last edited by C_Williams@RPM; May 1, 2011 at 08:32 PM. Reason: corrected error 12º was 11º.
Old Apr 29, 2011 | 11:52 AM
JayplaySS2's Avatar
JayplaySS2
Notes:
I'll do some prelim setup on how these stack up on p/v clearance - they will be much more friendlier in this regard, compared to LS3, because these have the 11° valve angle
Excellent point Charlie, forgot about how well the LS7/LS3 are compared to the LS2 needing the FAST.
I'll keep in touch now that I know which way to go
Old Apr 29, 2011 | 01:39 PM
Ragtop 99's Avatar
Ragtop 99
Below 2,500 RPM this type of combination will give up 15-20 ft lbs of torque and feel "soft" compared to a 235 cc head...it will even up from 2,500-4,000 and after that they will absolutely shine.
will they feel any softer down low than stock LS3 heads?
Old Apr 29, 2011 | 02:28 PM
0C_Williams@RPM
Former Vendor
they will be stronger than an LS3 head - they have less volume and flow more at low lifts..
Old Apr 29, 2011 | 03:44 PM
Sparo2's Avatar
Sparo2
Hey Charlie-
I guess I found my next set of heads for my new combo. Seeing how they are 11 degree heads means I can mill them even more than the LS3s to bump up the compression ratio. I'm really looking into switching over to E85 so I want to get as close to 13:1 compression to fully take advantage. Guess I'll be selling my LS3 topend combo.
I don't recall the exact specs of the cam you sold me (ZZ-014) or would it be better to get a bigger cam. I really want to squeeze as much as I can out of the stock bottom end but I still like to enjoy the car on the streets.
-Daniel
Old Apr 29, 2011 | 07:35 PM
0ffaxis's Avatar
0ffaxis
Anyword on a medium bore config? flow numbers and maby like 66 cc`s
I have a 418 ls3 and 62 cc is too small
Old Apr 29, 2011 | 07:56 PM
0C_Williams@RPM
Former Vendor
That's not a problem - I can machine this casting to nearly any size chamber (within reason)
Old Apr 29, 2011 | 08:21 PM
TwoValveKid's Avatar
TwoValveKid
The TFS heads are an LS3 head, but with all the heads coming out in the coming out soon it would be nice to see a good comparo on the same motor. Im building a ls3 based 427 here soon and the only real thing holding me back is head choice. TSP is making a small bore LS7 style head along with an LS3 head. Then there is you guy's small bore 7 head. So this is a good time be paying attention.
Old Apr 30, 2011 | 05:41 PM
  #33
Stang's Bane's Avatar
Stang's Bane
Interesting.....
Is this YOUR casting?
Don't mean anything by that, just a question.
If these things perform like I think they should, I can see a 540 rwhp stock shortblock ls2 in the future...
Old May 1, 2011 | 07:45 PM
  #34
BLKTA's Avatar
BLKTA
What's the valve angle on these heads and do they accept stock LS7 rockers? I've been looking for a LS7 small bore head for my LS2 402. It's an A4 car with a Circle D 5C stall and shifts at 7200 rpms.
Old May 1, 2011 | 08:30 PM
  #35
0C_Williams@RPM
Former Vendor
LS7 Valve Angle -12º - I looked at the design sheets to be sure - now I feel like dunce because Iv'e got to look over some previous posts and make a correction - I've been stating 11º and I need to correct that.
So yes, 12º - and all the LS7 1.8:1 rockers are a bolt on.
Old May 1, 2011 | 10:06 PM
  #36
BLKTA's Avatar
BLKTA
Thanks. Anxious to see some testing on these heads. Need a test subject?
Old May 2, 2011 | 10:40 AM
  #37
0C_Williams@RPM
Former Vendor
I've got several LS3 projects in-house, so I don't need any of those.
If you have a 6.0 or a 402, I'd possibly be open. But, bear in mind that this much cylinder head (on a 6.0) needs a truly optimized setup and 4.10:1 gears.
To Small Bore LS7 Heads - Available Now..
Old May 2, 2011 | 11:09 AM
  #38
BLKTA's Avatar
BLKTA
I have a LS2 402. A4, large stall with 3.73 gears. track operating range is 5000-7200 rpms.
Old May 7, 2011 | 01:42 PM
  #39
PRE-Z06's Avatar
PRE-Z06
Didn't see the valve size listed on the website and was curious. Thanks, Chris
Old May 16, 2011 | 08:53 PM
  #40
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
wow what a killer set of heads!
