New headers rubbing frame, what would you do?
Here's a picture of the usual problem on another car.
My car pictured here:
In my case, it's the same right side frame problem, and as you can see in the picture, in my car it's real hard against the frame.
The header bolts directly to the head, so obviously there is no real direct adjustment that can be done in this area. Using the search, I've come across several solutions.
(1) Contact the manufacturer. They will most likely exchange them for some that clear.
Most if not all of the big names stand behind their work.
(2) I read that there is some play depending on where the engine is mounted on the engine mounts. One "trick" I've read with header rubbing problems is to loosen the two bolts that hold the motor mounts to the cradle and adjust the motor towards the drivers side.
This fix has me a little concerned. Would moving the engine present any long term strain on the torque tube or drive components?
(3) Minor "clearancing" of the sheet metal lip on the passengers side may done as the lip is said to protrude off the frame inconsistently.
Seeing where those spot welds are, I don't see that a lot of "clearancing" cam be accomplished. Plus, grinding on an expensive sports car, is distasteful.
My questions to the Corvette Forum hive mind: How much clearance would you demand for trouble free miles of driving? 1/4 inch, 1/2 inch?
What are your suggestions for the fix? 1, 2, 3, or a combination of 2 & 3? Or is there something I've not read of yet?
Thanks for the help!
I don't really have any constructive advice, other than to contact the header manufacturer. Best of luck.
San
Other than that, nothing a pry bar won't fix.
...and 1/2" is plenty. 1/4" is plenty too.
There are many posts about this on CF too. Seen it myself, it looks like an allowable mfg tolerance on GMs part, its in an area that doesn't affect anything when stock. Easiest thing to do is as 1Corvette said just bend the lip out of the way......a lot easier to do before the headers are on.
May I ask what I'd be prying on? Would that flatten the header and bend the flange at the same time? Would it be wise to pry on a ceramic header?
Almost two years later and they have never rubbed/touched the frame.
Has anybody tried this??
The only thing that has me a little concerned, is whether moving the engine presented any long term strain on the torque tube or drive components?
Seriously now that is where the floor pan is seamed together. I was able to easily trim it back. You can cut it back or grind it down then
spot paint it with black spray. Then install the header.
Had the same concerns on first install. It is really No issue!
Removing even a 1/4 inch goes along way!
You can grind it back in to the spot weld if you like no worries.
Thanks to everyone who offered suggestions in this tread.
