Engine light help
Old Apr 30, 2011 | 09:51 PM
ZROCKET6's Avatar
ZROCKET6
Default Engine light help
I have 2008 z06 and the engine light came on and seems that it staying on, Possibilties question had the battery disconnected this week for 20mins,and put on prior to this haltech bee stinger II couple of weeks ago also checked my gas cap seems tight any answers would be appreciated..
Old Apr 30, 2011 | 10:11 PM
RicK T's Avatar
RicK T
If there is nothing obvious wrong then there's no point speculating. If you don't have a code scanner just take the car to Autozone or similar and pull the code. Then there's no doubt.
Old May 1, 2011 | 07:35 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Did it come on AFTER the CAI install?
Autozone will read the codes for free
Old May 1, 2011 | 09:11 PM
ZROCKET6's Avatar
ZROCKET6
The light came on a few weeks later but I haven't driven the car much do to weather .I noticed the idle surging a bit from 600rpm to 800 at idle sometimes..
Old May 1, 2011 | 09:35 PM
glenB's Avatar
glenB
Check your install and make sure everything is connected properly. If so, re install your stock air cleaner assy and disconnect the battery for 10 mins or so to clear the memory, then reconnect it and drive it again and see if the light is related.
Old May 1, 2011 | 09:55 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the air-bridge tube and insure its not slipped off the bottom of the intake.
Old May 1, 2011 | 11:22 PM
Surf2602's Avatar
Surf2602
Did the same thing to my 2008 ls3. Light came on a couple weeks after install. Onstar said it was the bank 2 oxygen sensor stuck lean. Had an appt with the dealer and it just went away. Didnt touch a thing. Hope it doesn't come back again
Old May 3, 2011 | 04:28 PM
ZROCKET6's Avatar
ZROCKET6
Last night I tighten all the clamps on haltech stinger 2 and made sure gas cap was tight ,disconnected battery well light is off. Drove car for a bit and so far no light
Old May 3, 2011 | 06:25 PM
VET4LES's Avatar
VET4LES
Good news.
To Engine light help
