2010 vs. 2011 paddle shifter
Old May 12, 2011 | 04:14 AM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
Originally Posted by HOXXOH
My concern was the accidental shift during panic mode while slamming on the brakes and steering clear of traffic to avoid a collision. Maybe I'm just a slow thinker, but my mind is still stuck in panic while accelerating away from the scene and it takes a while to react to what the transmission has done. This has happened twice and it's very unsettling trying to quickly understand why I'm traveling slower than other traffic because the shift never happened. I now only use S-mode when I intentionally want to use the paddles.
Okay, on my 2011, the transmission will downshift progressively as the vehicle slows in both "D" and "S". In "D", it reverts to fully automatic mode after the paddles have not been used for a few seconds.
The downshifts occur at about the time you would expect them to, so there is never a time when it is in such a high gear that you couldn't get decent acceleration. I even tried once letting the transmission shift from 6th to 5th, then floored the throttle as soon as 5th engaged. It accelerated smoothly with no engine lugging or bucking, and probably about as quickly as most other typical vehicles would accelerate.
Old May 12, 2011 | 04:17 AM
MisterMidlifeCrisis
Originally Posted by Shrike6
Never brace with the wheel.Plant your left food on the dead pedal and push yourself against the seat.
The seat feels pretty flimsy to be doing this. It feels easier to spread my knees and use them to hold me in place. Neither is a great solution, and if the 2012 seats are that much better, I'd be more than willing to upgrade to them.
Old May 12, 2011 | 12:51 PM
HOXXOH's Avatar
HOXXOH
I should have noted that I was in a lower gear (probably 2nd) and when accelerating with part throttle to get back to ~ 65 MPH, I expected a shift that never came. It just took a moment before I recognized what happened (the accidental paddle activation) and corrected for it.
Old May 13, 2011 | 12:39 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Originally Posted by gschub
I have a 2008 coupe A6, can anyone tell me if the trans will shift to
6th gear with wide open throttle. I have been told that at WOT the trans does not shift to 6th. My recent experience at the Mojave Mile the trans would not shift to 6th as long as I had it at WOT.
Thanks,
Jerry
The stock WOT shifting levels for a 5>6 are set at 169 mph/5000rpm's.
