Using two sets of brake pads?
Old May 19, 2011 | 05:15 PM
ScaryFast's Avatar
ScaryFast
Go here for Hawk:
http://www.andrew-racing.com/
Jay is a local racer and supports us well. If you're a NASA member you get a 10% discount.
Old May 19, 2011 | 05:19 PM
ScaryFast's Avatar
ScaryFast
Originally Posted by Ragtop 99
Why less heat? Seems like the brakes are removing about same amount of energy from the car, not accounting for the natural rolling/wind resistance during the extra couple seconds.
Efficiancy. Go drag your brakes on the street - you won't slow the car much but you'll still heat up the rotors from the friction.
Lots of beginners toast their brakes by using them this way. It's a comfort thing, having your foot over / on the brake pedal.
Now, you could argue that if you are braking later you will be stopping from a higher speed, which takes more energy (heat) to slow the car, but that's another topic altogether.
Old May 19, 2011 | 07:52 PM
jdwk's Avatar
jdwk
Originally Posted by ScaryFast
Go here for Hawk:
Thanks for the link. I sent him a mail. I think I'd probably be good with HT-10's. I don't want something that requires a lot of warm up time.
They are good chunk cheaper than the Cobalts.
Old May 20, 2011 | 02:28 PM
abstruse1's Avatar
abstruse1
(Excuse me while I pull on my ski mask to hijack this thread...there.)
I have a 2011 Grand Sport that's about to get the Edelbrock 499 hp blower, and I'm rumming Nitto Invo tires. For spirited street driving, are any of the aftermarket pads significantly better than the stock pads?
The stockers feel okay and aren't grabby, and maybe they exceed the tire's traction and ABS's ability anyway.
(Taking mask off now.)
Old May 20, 2011 | 04:11 PM
jdwk's Avatar
jdwk
The first thing you are going to want after the blower is stickier tires.
Then you will want better brakes. There is another thread posted recently that was looking for a compromise pad. The Carbotech Bobcat's seemed to do the trick for him.
But in short, there is nothing that is really trackable and streetable. There is no happy medium, only a crappy medium. If you plan on tracking just get some track pads and swap.
Old May 20, 2011 | 04:21 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
How do feel about noise and dust? The AX6 is big upgrade from factory. The Bobcat 1521 is a good choice for pepole who only fracture the law occasionally
Brief descriptions:
Carbotech™ Bobcat 1521™
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Carbotech™ AX6™ (1106™)
The AX6™ takes the place of the Panther Plus™ compound that was so successful. AX6™ was specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range (50°F to 1150°F +). Advanced compound matrix provides an excellent initial “bite”, high coefficient of friction, and very progressive brake modulation and release characteristics. AX6™ offers high fade resistance, rotor friendliness at all temperatures, excellent cold stopping power, and non corrosive dust. As a result, AX6™ is an excellent choice for Autocross & AX6™ has gained tremendous popularity with SCCA Prosolo/Solo2 competitors for its fantastic bite, release & modulation. Many drivers use the AX6™ for street driving as well, even though Carbotech doesn’t recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT a race compound, and should not be used as such. AX6™ shouldn’t be used by any intermediate or advanced track day drivers, and should not be used with “R” compound tires (racing tires).
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 3, 2014 | 11:27 AM
mikeCsix's Avatar
mikeCsix
Old thread, but just wanted to add...
All ScaryFast said is true. The energy being absorbed by the braking system is there whether you drag the brakes or use them hard and get off. The big difference is when you brake hard and get off, the cooling phase starts sooner. If you drag the brakes through the corner, cooling never starts until you get off the brake which could be when tracking out (dependent upon how long you drag the brakes).
Old Apr 3, 2014 | 11:51 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
He is talking about total heat in the brakes over the course of time on track. We have seen this time and time again with our race cars and team drivers. Those that say they are 'easy on parts' and will start braking at say the 5 marker will have more heat, and more wear on the brakes than those that wait until they are about to die going into the corner. Why you ask? Because over the course of a lap the guy that is 'easier' on the brakes and starts his braking sooner will spend more total time on the brake pedal causing a higher average temp in the brake and causing more wear. They might not see as high of a peak number but the guy that hits them hard and only for a short amount of time will have more time pumping cool air through the brake then causing heat build up in the rotor and pad.
That is why guys that are trying to break the pedal off in the car generally will have much longer life in rotors and pads than the guy just poking around the track.
Old Apr 3, 2014 | 02:03 PM
jcosta79's Avatar
jcosta79
I'm going to use this the next time my wife yells at me for popping the eyes out of her head.
"But, honey! I'm saving money on brake pads driving this way!"
Old Apr 3, 2014 | 03:27 PM
cclive's Avatar
cclive
This is the same concept that applies to street cars on a very long downhill. The guy who rides the brake gently all the way down the hill will be smoking his brakes. The guy who applies the brakes firmly and then gets off them will be fine.
Old Apr 3, 2014 | 04:14 PM
Former Vendor
Exactly...not only that but when you drag your feet on the brakes you can very easily over temp the pads causing glazing to the pad and warping rotors...
