Vararam whistle
Old May 30, 2011 | 07:45 PM
Nik_Bad's Avatar
Nik_Bad
Default Vararam whistle
I just installed the Vararam CAI and Corsa Sport on my 08 C6. Around 2800 RPM there is a slight supercharger/turbo spooling squeel. I have no clue what it is but I do know it was not there before I installed the CAI. Is this normal?
Old May 31, 2011 | 02:26 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Mine did the same thing.
Old May 31, 2011 | 02:45 PM
Crowhater's Avatar
Crowhater
I took mine apart the other day to check my filter and to my suprise the foam gaskets had moved and the spaces it caused could let dirt into the engine. I removed all of the gaskets, then pulled the double side tape off the foam and used yellow weather strip glue to apply them. I made sure I had a good seal to the air cleaner. For as much as these things cost I was not impressed.
Old May 31, 2011 | 04:02 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Regluing the seals are the first thing you should do. VR101.
Old May 31, 2011 | 07:53 PM
xfactor28's Avatar
xfactor28
Mine does the same...did refastening the foam gaskets with glue stop the whistling?
Old May 31, 2011 | 08:17 PM
Swiftrider08's Avatar
Swiftrider08
I have the newer version of the Vararam and saw no reason to re-glue the seals. They fit very well now. The whistle is because you have an air leak. Something moved on you when you put the bottom and top together, or you have a leak at one of the flex couplers.
Did you install the throttle body spacer? If so, re-check those bolts. Suppose to re-tighten them after a heat cycle or two.
Old May 31, 2011 | 10:33 PM
TommyV's Avatar
TommyV
Unless they are now using something other than the double sided tape, I would check it regularly to make sure the foam has not moved. The engine heat melts that tape.
Old May 31, 2011 | 11:19 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Gluing in the gaskets sounds like a good idea.
To Vararam whistle
