Question about DYNO results
Old Jun 10, 2011 | 01:08 PM
Z06Ronald's Avatar
Z06Ronald
Default Question about DYNO results
Hi all,
Below is a DYNO sheet of my Z06, and I would like to invite you to comment on the results (be they disappointing or encouraging)...
Because the picture was resized and is rather small (it's in My Garage), I include a link to a slightly larger picture on my Facebook account (should work, my albums are public ).
I have a question to the experts, here on the forum. How do these results, which were gathered while the car was in 5th gear, translate to the way that measurements are taken in the US? It's commonplace to dyno cars in 4th gear, I believe?
Is it as simple as applying a correction factor of .74 (4th gear ratio of 1:1, 5th gear ratio of 1:0.74), or is physics more complicated than that?
Thanks in advance everyone!
Ronald
Legend:
(Max) Vermogen = (Max) HP
(Max) Koppel = (Max) Torque (expressed in Nm)
Toerental (TpM) = rpm
Vochtigheid = Humidity
ONGECORRIGEERD = UNCORRECTED
Note: data represent measurements in 5th gear
Old Jun 11, 2011 | 05:30 AM
Z06Ronald's Avatar
Z06Ronald
ttt
Old Jun 11, 2011 | 08:53 AM
6Speeder's Avatar
6Speeder
It's hard to comment when you don't know how that correlates to how most folks post their results. I can say that you shouldn't change the numbers based on gear ratios, torque and horsepower are what they are. BUT, it would be best if you dyno'd in fourth gear and posted SAE corrected numbers.
I'll bet there aren't that many Z's where you are, enjoy the ride!
Old Jun 11, 2011 | 05:13 PM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
The main thing I noticed is that your HP and torque lines do not cross at 5200 RPM. I'm no expert, but I think you're right about the gear used.
Old Jun 11, 2011 | 05:58 PM
Z06Ronald's Avatar
Z06Ronald
The reason for that is that the results are not expressed in ft-lb, but in Nm.
Old Jun 11, 2011 | 07:15 PM
djbrun's Avatar
djbrun
Just to clarify for anyone that can not read the graph.
Max HP 457
Max Torque FT-LB 451.27
DJ
Old Jun 11, 2011 | 07:38 PM
Z06Ronald's Avatar
Z06Ronald
Max HP 457
DJ
Yep, that's right
Unfortunately it's (largely) in Dutch also, hence the legend that I have included at the bottom.
Old Jun 11, 2011 | 07:39 PM
djbrun's Avatar
djbrun
Is this with just a tune?
DJ
Old Jun 11, 2011 | 07:43 PM
Z06Ronald's Avatar
Z06Ronald
DJ
No tune yet, DJ. Please click at the link "My Garage" in posting # 1 to see the modifications of my "Zee". And again, what puzzles me is that everything was measured in 5th, and how that relates to what is commonplace in the US!
Old Jun 11, 2011 | 08:22 PM
Chris_B's Avatar
Chris_B
Originally Posted by Z06Ronald
Hi all,
Ronald
Legend:
It is best to measure in a direct (1:1) gear, rather than an overdrive gear. That said, Dynojet's are roller dynos that have a lot of inconsistencies built into them, such as tire pressure, camber setting, type of wheel, type of tire, strap tension, etc. Plus, they have that famous "correction factor", which is an arbitrary number chosen to convert measured torque to wheel horsepower. I've seen rather large (10% or more) differences between one roller dyno and another, and large differences on the same dyno on different days or with different operators. If you are really concerned about the accuracy of a chassis dyno result, find a nearby hub dyno (like a Dynapack) and give it a try. Expect to pay a little more as those are more expensive pieces of equipment, but they are worth it, in my opinion.
Chris
Old Jun 11, 2011 | 08:38 PM
Z06Ronald's Avatar
Z06Ronald
Chris
Hi Chris,
Very useful comment, thanks!
I did not know that the differences between the various roller dynos had such a huge variation; 10% or more, wow!
BTW, I am not concerned, just very curious if my modifications thus far (CAI, LT headers, intake manifold, mufflers) pay off. I am not dissatisfied or disappointed about my Z06 either. On the contrary, I LOVE my baby!
Ronald
Old Jun 11, 2011 | 10:25 PM
glass slipper's Avatar
glass slipper
Chris
Quite frankly, it doesn't matter what gear you use as long as you use the same one everytime. The DynoJet pure inertia chassis dyno is the most consistant and accurate chassis dyno out there because they use a constant weight roller drum to measure HP. While it's true that different tire pressure, tires, and/or wheels will have an impact on the HP reading, that's true of all roller type chassis dynos. As for the "arbitrary" correction factor, that's far from the truth...STD and SAE correction factors use an exponential equation involving temperature, absolute air pressure, and humidity to arrive at the proper CF. I'm not sure where you got the "arbitrary" term from.
It might interest you to know the Dynapack is probably the least accurate chassis dyno made. Yes, it eliminates differences in air pressure and tires/wheels but those are variables that can be controlled by you the owner. Unfortunately, the Dynapack introduces constantly changing unknown inaccuracies. When the hub gets bolted to the Dynapack, it drives a hydraulic pump. The pump RPM and pressure are used to calculate HP which is pretty simple on the surface but much more complicated once you start digging a little. Dynapack sources the pump from Eaton and the first thing they do is tear the brand new pump down to be "blueprinted". That alone tells you how inconsistent hydraulic pumps are...every pump has a different amount of internal leakage/friction. The blueprinting process makes them close initially but then wear takes its toll from day one causing internal friction/leakage to increase as time goes forward. I'm a mechanical engineer who specializes in hydraulics and I calculate hydraulic HP using the formula HP=GPM*PSI*.0007...it's a very rough estimate at best and I'd never present it as the most accurate. There's really no way to accurately measure HP using hydraulics but it certainly is easier. Chassis dyno numbers should never be touted as accurate, they're just a tool to measure increases (or decreases) after mods or as a tuning/trouble shooting aid.
Old Jun 11, 2011 | 10:35 PM
Z06Ronald's Avatar
Z06Ronald
^^^ I'm learning with every posting here!
Old Jun 11, 2011 | 10:41 PM
Chris_B's Avatar
Chris_B
It might interest you to know the Dynapack is probably the least accurate chassis dyno made. Yes, it eliminates differences in air pressure and tires/wheels but those are variables that can be controlled by you the owner. Unfortunately, the Dynapack introduces constantly changing unknown inaccuracies. When the hub gets bolted to the Dynapack, it drives a hydraulic pump. The pump RPM and pressure are used to calculate HP which is pretty simple on the surface but much more complicated once you start digging a little. Dynapack sources the pump from Eaton and the first thing they do is tear the brand new pump down to be "blueprinted". That alone tells you how inconsistant hydraulic pumps are...every pump has a different amount of internal leakage/friction. The blueprinting process makes them close initially but then wear takes its toll from day one causing internal friction/leakage to increase as time goes forward. I'm a mechanical engineer who specializes in hydraulics and I calculate hydraulic HP using the formula HP=GPM*PSI*.0007...it's a very rough estimate at best and I'd never present it as the most accurate. There's really no way to accurately measure HP using hydraulics but it certainly is easier. Chassis dyno numbers should never be touted as accurate, they're just a tool to measure increases (or decreases) after mods or as a tuning/trouble shooting aid.
I'm an engineer as well who has researched the issues you present. The Dynapack is consistently within 0.3%, which is much better than any roller dyno I've studied (so far). Yes, they do a lot to get it that way. The whole reason they even exist was to get past the inherent inaccuracies that are part of the roller dyno approach. While there may be plenty of argument on which type of induced load is best, the Dynapack has proven in the field to have very good repeatability, which is far more important to a tuner than absolute accuracy anyway (as you have alluded to).
Also, I was not referring to SAE or STD corrections. What is more interesting is how Dynojet converts from measured torque to horsepower. The factor that manufacturer has chosen was, indeed, arbitrarily selected based on some empirical data. That factor has a known error that grows with horsepower, meaning that the more power the engine/chassis combo being testing produces, the more off the results are. Also, I've seen plenty of pulls on a roller dyno. I'm not sure how anyone can say that the way each vehicle is strapped down is in any way repeatable. In practice, it is far from it. Try changing camber a degree or two and watch the numbers move. Heck, the roller dynos around here vary over 50HP from place to place and operator to operator just in the 450-550 WHP range alone.
Chris
Old Jun 11, 2011 | 10:42 PM
glass slipper
You can multiply torque all day long but HP is HP, it doesn't matter what gear you use. (The torque quoted is crankshaft torque as measured by the rear wheels minus friction losses.) There will be HP differences due to inertia and oil windage in the transmission/differential depending on what gear you use. As you go up in gears, you have less HP loss to inertia because the dyno run is longer but more HP loss to oil windage in the transmission/differential because the shafts/gears are spinning faster through the oil. The main advantage to using 4th gear is the fact there are no gears for the power to flow through...the input and output shafts are "locked" together. Power has to flow through gearsets for all other gears meaning there's about 2% more HP loss due to friction at the gear teeth. See if you can go back for another dyno run and this time use 4th gear with an SAE correction factor so you can compare it to others here understanding there's really no way to make an exact correlation.
Old Jun 11, 2011 | 11:19 PM
glass slipper
Chris
The very idea of consistency on a chassis dyno is laughable at best. SAE engine dyno tests specify a particular intake air temperature, coolant temperature, humidity, absolute air pressure, and oil temperature...basically the tests are done in a climate controlled setting. There's no way you can repeat any of the above to an accuracy of .3% on a chassis dyno making your claim pretty silly. While the Dynapack may be repeatable with a given input within .3% on runs back to back, the absolute accuracy of the Dynapack is very questionable due to the use of hydraulics to "calculate" HP. A run done a year later with the same input will definitely result in an error of more than .3%...that's the way hydraulic pumps are, constantly changing internal friction/leakage. And we all know hydraulic oil viscosity changes with temperature, there's even a correction factor in the Dynapack to account for that too. Anybody can be consistently wrong.
I not only bolded a sentence in your second paragraph, but I made it red to point out a glaring error in your understanding of how a DynoJet dyno works. On a DynoJet, HP is measured and Torque is calculated...maybe you would like to "research the issues I presented" a little more. Please tell us what the "arbitrarily selected based on some empirical data" factor is. Since there is no calculation of torque to HP, that makes your claim of a "factor" pure BS.
I'd also like an explanation of how differences in strapping the car down makes a difference. And while I can see how more toe-in or toe-out will eat up some HP, give us a good explanation on how camber affects HP.
Old Jun 12, 2011 | 01:03 AM
HC Mechanic's Avatar
HC Mechanic
To Question about DYNO results
Old Jun 12, 2011 | 03:24 AM
Chris_B's Avatar
Chris_B
I'll address your first bit on Monday (time permitting), as my notes are at the office. By the way, a lack of readily available backup information does not in any way constitute "BS". If you chose to adjust your implied tone, the forum would be the better for it.
However, regarding strapping down and camber settings, one who has studied and tested tires can easily see how horsepower consumption through tire deflection is not a trivial issue. The harder the car is strapped down, the more load the tire sees. More vertical load --> more deflection --> more horsepower loss. It's a lot like suffering a reduction in fuel mileage due to under-inflated tires.
Camber has a similar effect, but it is closer to a zero sum game. The more negative camber, the more the inside tire sidewall is loaded, but also the less the outside is loaded. Does one sidewall's increase power consumption equal the other's decrease? Maybe, or maybe not. Depends on the tire construction, air pressure, air temperature and other factors. Not so easy and repeatable, is it?
And before anyone dismisses tire deflection losses, consider one case that I'm familiar with, even though I'll admit it is a bit extreme. Some years ago, I was communicating closely with an very bright and highly experience tire engineer over at Goodyear. He had been developing top fuel and funny car drag racing slicks. From their testing, they had discovered the dragsters were losing 550HP (peak) PER TIRE during the 1/4 mile run. That's 1100HP being sucked up!
OK, so most street tires do not deflect anywhere near those levels, but we can say that the losses are certainly not trivial. And if we are willing wave off differences in alignment settings, tire pressures, tire temperatures or vertical loads due to the straps, we can't expect to be dealing with repeatable dyno results. Let's face it, the better engine dynos are far better for accuracy, but as long as we have resolved to measuring horsepower while the engine is still in the car, we ought to at least remove one of the biggest and least consistent variables from the equation -- the tires.
Chris
Old Jun 12, 2011 | 10:08 AM
glass slipper
I have no implied tone, I was very clear where you were stating BS. This is the "Tech/Performance" section of the forum where people come to get correct answers...if you chose to adjust the accuracy of your posts, the forum would be better for it.
Most of the load from the straps is horizontal, the vertical portion is a small amount. If the tires are in the correct range of proper tire pressure, there will not be a sufficient amount of tire sidewall deflection to make a measurable difference. The amount of HP loss due to tire deflection is a very small amount...a very small percentage of a very small number is insignificant in the overall scheme of things as you'll see below.
On a 12" wide 26.8" tall tire, the vertical change at each sidewall due to a 1° change in camber from an initial setting of 0° is very small. Again, a very small percentage of a very small number is insignificant in the overall scheme of things. When the decrease in HP loss from the other sidewall is taken into account, it takes you to zero. If camber caused excessive HP loss, you wouldn't see racers running around with 3° negative camber.
You do realize HP is heat so HP going to tire deflection creates heat in the tire according to the 1st Law of Thermodynamics which you should be aware of as an engineer. Also, 550 HP is ~410300 Watts...if you've ever grabbed a 60 Watt incandescent light bulb, common sense would tell you 410300 Watts going to overcome tire deflection would render that drag slick a molten pile of rubber. I wasn't there for your conversation with that tire engineer so I don't know who is BSing who. Please try to verify info before posting so I'm not put in this position.
Chris
The C6 platform with a manual transmission loses about 50-60 HP on a chassis dyno due to drivetrain losses that consists of oil windage in the transmission/differential, gear tooth friction at the ring and pinion, seal drag in the transmission/differential/wheel hubs, brake drag, bearing friction in the transmission/differential/wheel hubs/CV joints, inertia of all the rotating components from the clutch to the tire, and tire sidewall deflection (feel free to add any places I missed). HP loss to tire/wheel inertia and sidewall deflection is only about 10-15 HP of the 50-60 HP total. Even a large 10% increase in HP loss to tire/wheel inertia and tire deflection will only give a 1.5 HP increase worse case scenario. Small changes in wheel/tire weights, tire pressure (within the correct range of proper tire pressure), or sidewall deflection have a very small impact on the total losses. So we remove the tires and hook up to a pair of hydraulic pumps that have no consistency from one year to the next and a HP calculation that is a guess at best...good move. The Dynapack is a great tool for tuning a car or troubleshooting a problem but so is a Mustang or DynoJet (with power absorption feature) and you don't have to go through the cumbersome task of taking the wheels off and bolting the hubs to a machine. If you like the Dynapack better, rock on...just don't think you're getting something any better than the others. All chassis dynos are a tool to be used for measuring changes due to mods, tuning, or trouble shooting...accuracy and consistency are not their forte. Having said that, a pure inertia chassis dyno will be the most accurate and consistent all other things held constant however it's not the best for tuning or trouble shooting since you can't control the rate of engine acceleration.
Old Jun 12, 2011 | 02:26 PM
Chris_B's Avatar
Chris_B
I would buy that argument for 101HP Fiat 500's. However, put a 600+HP Corvette on a roller dyno and you have to strap the hell out of the thing to keep the tires from spinning. You simply MUST have a considerable downward vertical load -- just like we use wings, splitters and tunnels on race cars to create downforce. The drag is not only an issue, it is a variable that is one of the hardest to replicate (and verify the correct replication thereof), especially if testing on different days with different operators. Everyone looks at the nice charts and graphs, but where does it list the tire/suspension settings? If this tire stuff is no big deal, then explain to the idiot typing this why we can take off 20" wheels and replace them with 18" wheels (with similar overall tire heights) and gain at least 20-30HP on a Dynojet every single time. Anyone? Bueller? We're testing a highly-modified Camaro right now that we can't even put on a Dynojet. There is no way we could keep the tires hooked up, and we're only at about 1100WHP with the baseline break-in tune. The damn thing cranks out 550 lb-ft of torque at 2k RPM at part throttle, long before the 22PSI+ boost level that we will peak at. I've witnessed attempts at putting a 1000HP IMSA race car on a Dynojet (with fresh racing slicks) and it was all a bucket of laughs!
Cornering speeds with camber settings that are correct for the tire and track far outweigh HP loss on the straights, especially for traction-limited cars. This is not an arguable point at all. The example I provided was for drag racing cars, for which horsepower loss is certainly a concern, but far outweighed by traction for the fuelers with over 8,000HP. They can afford the loss if they can get the car out of the hole any better at all. And, the engineer I was referring to was the man responsible for drag racing tires at Goodyear at the time (may he rest in peace). If you have a better source or higher credentials, please share them so we can evaluate your input. I am always open to learning something new.
550HP = 410kW, yes. Those tires are not kept in an oven. They experience cooling via convection (the air, especially at over 300mph), conduction (mounted on aluminum wheels -- which is why they don't use carbon fiber or they would melt) and radiation (the environment). Tire temperature management is a real concern on those cars. Incandescent light bulbs are not exactly the most energy efficient in terms of lumens versus heat. I can touch a 60 Watt LED and get very different results. The blower and belt themselves consume hundreds of horsepower and are (more times than not) still there after the run. Your claims of BS are, well, BS.
First, drivetrain losses are not constant, even on the same vehicle platform. The more torque an engine makes, the more deflection in the crankshaft, transmission shafts, transmission case, driveshaft and the final drive gears, case and shafts. Many of these deflections cause power-robbing bearing and gear misalignments. It all adds up. As far as how much the tire component is factored in, please refer to my question above.
Arguing about accuracy, while a little bit entertaining, is not what really concerns me. I'm far more interested in repeatability, which is why I look at all roller dyno results with a jaundiced eye. Both the stopwatch and the butt dyno are very sensitive to actual, measurable changes, not overall accuracy.
Chris
