MGW Shifter
Old Jun 30, 2020 | 11:55 AM
Vettes4life11's Avatar
Vettes4life11
Originally Posted by SUB VETTE
Thinking about changing my 06 Z51 manual shifter over to an MGW and would appreciate any feedback pro or con from anyone who has done so.
just replaced gen 1 MGW with this and love it!
Old Jun 30, 2020 | 10:28 PM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
I love my MGW with their Race shifter ****
Old Jul 11, 2020 | 05:45 PM
LOURDESBELLE
Default Mgw
Now I love my MGW shifter even more with their Flatstick/ball shifter ****😁
vettes4life11, thank you. Your pic made me swapped over,lol.
Old Jul 12, 2020 | 11:06 AM
Dutch08's Avatar
Dutch08
Originally Posted by LJD51
DO IT!!!
.... with an old school white ball shift ****.
Old Jul 13, 2020 | 08:01 AM
JetstreamGS's Avatar
JetstreamGS
Love it. Only complaint is that it seems to have increased my cold second gear grinding.
Old Jul 14, 2020 | 10:29 PM
LOURDESBELLE
Gear grinding? Sounds like the trans needs to be looked at.
Old Jul 17, 2020 | 09:48 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
When was the last time that you replaced the fluid in your transmission? I had the same 2nd gear cold grind when I first got mine with 70K miles.
Changed the fluid (it REALLY needed it) and that went away.
Old Jul 17, 2020 | 09:51 AM
JetstreamGS
I’ve never changed it. Car only has 8K miles. That was going to be next. What fluid did you use?
Old Jul 17, 2020 | 11:51 AM
Dutch08's Avatar
Dutch08
I had some 2nd gear grind when cold. Tried Mobile 1 and found no difference at 50K miles when I replaced my clutch for a different reason. I switched to AMSoil at 55K and got a noticeable improvement, no grind when cold with maybe just a tight feeling for the first or second shift. I have a MGW shifter which I would recommend. Whatever oil you put in the transmission if its a T56 make sure it meets DEXRON III spec.
Old Jul 18, 2020 | 12:13 AM
thesixtyfoot's Avatar
thesixtyfoot
Do it and never look back!
Old Jul 23, 2020 | 09:33 AM
puterami's Avatar
puterami
I just went with the factory fluid.
Old Jul 29, 2020 | 09:58 PM
Tom Barger's Avatar
Tom Barger
2nd Gear
Default C6 second gear has scraped since day one.
I have an 09 that second gear has scraped since day one. Been to 2 different dealerships, and they would never acknowledge the problem. Said it was acceptable. I drove the car very little because it bothered me. Well 11 years later I finally fixed it. A new MGW shifter, Redline Transmission fluid, and the anti venom mod. No more scrape, no more notchiness. Finally the car I always wanted.
Old Jul 29, 2020 | 10:30 PM
  #33
JetstreamGS
Good to hear, what's the anti venom mod?
Old Jul 29, 2020 | 10:45 PM
  #34
Tom Barger's Avatar
Tom Barger
2nd Gear
Default Anti Venom Mod
The anti venom mod is when you add one or two (your preference) Dorman Copper washers (part # 65277) on the transmission detent plug. This plug applies pressure to your shifting forks. Adding a washer (or 2) takes the notchiness out of the shifter. I used 2 washers with my MGW shifter. It now reminds me of my old old 65 of yesteryear that was like cutting through butter. Google Anti Ventom mid for location of plug.
Old Jul 30, 2020 | 09:34 AM
  #35
jonjoy's Avatar
jonjoy
BG products SYNCRO shift II made to replace ATF in manual trannys. You will not believe how Quite the car can get!
