titanium or ss valves
Old Jun 28, 2011 | 09:33 PM
z06rules39's Avatar
z06rules39
Cruising
Default titanium or ss valves
i need some advise on whats best on a modified ls7 engine i want to upgrade my valves with either tit or ss valves what you guys think will work best ?
Old Jun 28, 2011 | 09:37 PM
craftfox's Avatar
craftfox
it is a big valve, GM does not use the titanium valves because they are cheap. they use them because when you spin a 2.25 valve up that high, and do not want to use a monster spring, you need a light valve to keep things moving and not bouncing.. if for some reason you feel the need to replace the factory valves, they need to be titanium
Old Jun 28, 2011 | 09:53 PM
z06rules39's Avatar
z06rules39
Cruising
ok so if im not going over 8000 rpm do you think titanium are needed? i heard that ferras make a light weight ss valve the work great below 8000rpm.
Old Jun 28, 2011 | 10:10 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Not going over 8000 somehow minimizes the potential for problems? Spend the extra few dollars and do it right.
San
Old Jun 28, 2011 | 10:28 PM
SteveRiellyNZ's Avatar
SteveRiellyNZ
Ditto on the above....Ferrea have a complete range with springs, retainers, and can do custom as well:
http://www.ferrea.com/domestic.php
Probably just call them, tell them what you need to do, and they'll give you their advice.
If you like what you hear your onto a winner.
Old Jun 29, 2011 | 03:58 AM
HC Mechanic's Avatar
HC Mechanic
San
I can totally hear you saying that "old man"
Del West also make really nice valves. You get what you pay for.
Old Jun 29, 2011 | 07:05 PM
Gering's Avatar
Gering
Tolero Apto Victum
San
If you buy the best, you only cry once. As the saying goes.
Good luck on your build.
Old Jun 29, 2011 | 07:52 PM
z06rules39's Avatar
z06rules39
Cruising
San
So you are saying that the titanium valve are better than the ss for my project?
Old Jun 29, 2011 | 07:55 PM
z06rules39's Avatar
z06rules39
Cruising
Default Need stock tires for Z06 nitto invo
Can someone tell me how can i some Nitto invo for my stock wheels?
To titanium or ss valves
