Can't Get Alignment Right
Old Jul 19, 2011 | 08:04 AM
C7&7's Avatar
C7&7
Originally Posted by AU N EGL
Not really
Camber is OFF both front that is why it pulls.
Front
left -.55
right -.43 just enough to pull right
Camber should be -.75 on BOTH SIDES EXACT not a RANGE
Rear is OK
Hmmm.... Interesting. the camber number should be a solid .75 on both sides huh.
Old Jul 19, 2011 | 09:46 AM
Kenny94945's Avatar
Kenny94945
Need more info.
OP stated ".....shops, and the aligned within spec perfectly. Then after a few weeks the car starts pulling to the right again......"
If alignment was off from the "get-go" why the above quote from the OP?
From the 05 service manual (Page 3-17) here are the alignment specs:
Camber = Front -.45 +- .60 Rear -.45 +-.50
Camber Cross = Ft +-.60 Re +-.50
Caster = Ft 7.9 +-.6
Caster Cross = Ft +-.6
Total Toe = Ft +.1 +-.2 Re .0 +-.2
Steering wheel angle Ft 0 +-3.5
Trust Angle Re .0 +-.2
Z Trim height Z51 = 1.52 to 2.02 inch preferred 1.77 in
D Trim Z51 Coupe = 4.51 to 5.02 in preferred 4.76 in
(I still vote something is loose and not holding the adjustment)
Old Jul 19, 2011 | 09:49 AM
C7&7's Avatar
C7&7
Yeah the car felt fine for a few days / maybe a week after the alignment. Now it is pulling again.
Old Jul 19, 2011 | 02:16 PM
fnsblum's Avatar
fnsblum
That is actually a very good alignment and should not pull either way on a flat road. If the cross camber was .5 I would agree but not with .12. Have you rotated the fronts yet? Later! Frank
Old Jul 19, 2011 | 02:38 PM
C7&7's Avatar
C7&7
Nah I'm going to do that tonight.
Old Jul 19, 2011 | 04:46 PM
AU N EGL's Avatar
AU N EGL
take a look at the A-Arm bushings. Where the A-arm attaches to the frame. One side may be squished and the other side not squished.
Old Jul 19, 2011 | 06:46 PM
fmcokc's Avatar
fmcokc
I say try the tire swap first.
I spent 6 months fighting this same thing except my pull was to the right. Always to the right.
Checked the alignment numerous times. Marked all the eccentric bolts with paint spots. Checked, marked and re-checked everything I could think of.
Turns out it was the front tires. Swapped them side to side and it went away for the most part. (Just ran them backwards as a test, NOT actually dismount and remount)
Funny thing is after I replaced all four tires with a new set, they did it again. (Kumho SPT) I have a propensity to take clover-leafs at speed shall we say. I can only theorize that all that cornering in one direction caused a shift or something in the belts of the front left tire. Once I switched to Continental's, no more pull and everything was glorious.
Chris
Old Jul 19, 2011 | 09:00 PM
TMyers's Avatar
TMyers
I would also check the tires, belts can a do shift. While I did not have a puill problem I have a vibration that balancing the wheel on every machine possible would never fix. Change tires and it was gone.
Old Jul 20, 2011 | 11:14 AM
C7&7's Avatar
C7&7
I tried the tire swop last night, and it seems to have helped a little bit actually. Has me thinking it could possibly be a tire.
Tomorrow it will go back on the alignment rack to get that all checked. Will be interesting if it needs adjustment again. I will post of the results tomorrow.
Thanks for everyone's input.
Ironically I have been working a deal on these wheels and tires, so replacing the tires will happen by default in the next few days:
http://forums.corvetteforum.com/c6-p...han-500mi.html
Old Jul 20, 2011 | 01:25 PM
Pylons's Avatar
Pylons
Not really
Front
left -.55
Rear is OK
a tenth difference side to side is not going to make it pull...you could probably see that kind of change just by putting a passenger in the car
and -0.75 is not some sort of magic no-pull number
I have over 2 degrees negative on my car with a tenth difference side-to-side with no pulling issue
Old Jul 21, 2011 | 09:15 PM
Bill Dearborn's Avatar
Bill Dearborn
The alignment numbers can be pretty tricky to get right down to the last tenth and it usually doesn't make that much difference. Here are the GM specs from the Service Manual (Z51 is FE3):
The best thing is to get it set as close as possible to the base number but a lot of variables can make that extremely difficult to do. I suspect the OP has some other issue although one thing that happens a lot on C5s and C6s is slipping of one of the cam adjustment bolts. That will affect camber, caster and toe in one shot. If in the front the steering wheel will not be centered but the car shouldn't pull much and will go straight with the wheel off to one side. However, in the rear the car will dog walk and this can be felt as a pull to one side or the other.
Bill
Old Jul 21, 2011 | 10:04 PM
C7&7's Avatar
C7&7
Well I got the car back from the alignment shop this afternoon and everything checked out fine. They're thinking it is a tire also, but they set it up to drift "less" to the right, and it feels A LOT better.
Here is where she was today:
It feels a ton better, but I am going to use this opportunity to buy some CCWs and new tires...I am excited:
Old Jul 22, 2011 | 09:29 AM
  #33
gsx1300r's Avatar
gsx1300r
Great thread...
