Track alignment specs???
Old Jul 18, 2011 | 08:56 PM
matteo's Avatar
matteo
Default Track alignment specs???
I have a C6 - Z06 that sees a lot of track and so I just had a track alignment done. The specs came from "Pfadt's" website and call for 0 to -1/16th maximum toe (out) at the front, and -1/8th to -1/16th toe (out?) at the rear.
The alignment shop assumes that negative (-) means toe out on both ends, but I've never heard of toe out at the rear. Neither had they.
That's the way they aligned the car. Is this correct?
The rear oversteer is an adventure in most corners. Please help...
Old Jul 18, 2011 | 09:13 PM
TMyers's Avatar
TMyers
I think we need a response from Pfadt on this one. I always assumed negative met in.
Old Jul 18, 2011 | 10:51 PM
RicK T's Avatar
RicK T
Excerpted from aligncraft dot com:
Toe-in, or positive toe, is defined as the front of the tires being closer together than the rear of the tires. Toe-out, or negative toe, is when the rear of the tires are closer together than the front of the tires.
Old Jul 19, 2011 | 06:30 AM
AU N EGL's Avatar
AU N EGL
Good Track non street alignment
Front
Camber -2.0*
Caster, Max but equal
toe: 1/32" OUT to 1/16" OUT for tight courses 1/8" out is for Auto-X
Rear
Camber -1.0*
tow 1/32" IN to 1/16" for tight courses
Old Jul 19, 2011 | 08:30 AM
matteo's Avatar
matteo
Thanx "Rick T", if negative (-) toe means that the rear of the tires are closer together, then the rears are toeing out* which is the oposite of what logic says should be correct, and "AU N EGL"s track alignment. Easy to see why the car is so loose at the tail, and the front turns in so well.
I think I'll give 'Pfadt" a call just to confirm everything. They're a great good source for parts and information.
Old Jul 19, 2011 | 05:49 PM
TMyers's Avatar
TMyers
I just got off the phone with Pfadt for another issue and ask about this. - means toe in.
Old Jul 19, 2011 | 06:08 PM
RicK T's Avatar
RicK T
Interesting.......so a conflict in terminology?
Old Jul 19, 2011 | 08:57 PM
TMyers's Avatar
TMyers
This may very well be why my suspension guy was confused when I showed him the Pfadt sheet. Everything I have every read says that the C6 like a little toe in. When my tech saw it, he went toe out?
Anyway for dual purpose this is what I run:
Front
Camber -1.6*
toe: .09 (toe in)
Note: I can flip my upper pins and I get 2.4 for camber and toe that is slightly out.
Rear
Camber -1.0*
Toe: 0.0
As I don't have a trailer yet I have to make tire selction prior to going to the track and the drive can be 400 miles round trip plus track time. Mostly autocross with a couple of HPDE thrown in. Currently the tire of choice for this are my Firestone runflats, don't laugh we had a really wet event and I beat everyone by 3 seconds or my R888's.
Old Jul 20, 2011 | 07:23 AM
AU N EGL's Avatar
AU N EGL
and my dedicated track car
Front
18x12 with 18x305/30
Camber:-2.5*
Caster: Max but equal
Toe: 1/16" IN
Rear
18x13 with 18x335/30
Camber -1.5*
Toe 1/16" OUT
Old Jul 20, 2011 | 09:48 AM
TMyers's Avatar
TMyers
How do you get around the computer having tires that are almost the same height?
Old Jul 20, 2011 | 04:36 PM
el es tu's Avatar
el es tu
turn the computer control off with the traction button
Old Jul 20, 2011 | 04:59 PM
TMyers's Avatar
TMyers
I thought it was an issue regardless of traction control off or on.
Old Jul 21, 2011 | 09:23 AM
AU N EGL's Avatar
AU N EGL
No. Not if the traction control is turned OFF.
The rear wheel only needs to be slightly taller then the front, not the 1 or 1.5 inchs ppl claim with TC/AH ON.
Know several guys with C6s that run 18x10 18x315/30 fronts and 18x11 18x315/30 rear with no problems. TC/AH is OFF
Old Jul 21, 2011 | 11:03 PM
TMyers's Avatar
TMyers
That is good to know, 19 inch Hoosiers are pricey.
Old Jul 22, 2011 | 07:21 AM
AU N EGL's Avatar
AU N EGL
19s are why too expensive
18" wheels are the only way to go for track days.
and scubs can be bought or other racing scub slicks 4 for $200
Old Jul 22, 2011 | 03:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Front
Camber:-2.5*
Toe: 1/16" IN
Rear
Camber -1.5*
Toe 1/16" OUT
Was wondering how you get away with toe out in the rear. My Z06 is very twitchy coming off from corners if I have 0 toe. Last time at the track I had 0 rear toe and had to crank in a flat turn on each side to get the back end to settle down and let me roll into the throttle the way I wanted to. I was running 285/35/18 Nitto NT05s in front and 335/35/19 in the rear. I can't imagine how high the pucker factor would have jumped if there had been toe out.
Bill
To Track alignment specs???
