150mph
Old Aug 5, 2011 | 07:55 PM
gunone's Avatar
gunone
Default 150mph
why does my car feel like it shuts down then takes off at 150mph?
Old Aug 5, 2011 | 08:24 PM
smurfkiller's Avatar
smurfkiller
auto or manual? rev limiter in 4th is right around 150. i have a 6spd so i cant say where the shift points are in the auto. but i would say it might be a lag in shifting or something.
does your traction/active handling light come on? once i changed my tires (differnt sizes from stock) at high speeds it will turn on the traction control. some times it stays on and i cant speed up till i turn it off.
Old Aug 5, 2011 | 08:37 PM
gunone's Avatar
gunone
07 z06 i did change the tires and yes it happens in 4 gear .it feels like the breaks come on or something
Old Aug 5, 2011 | 10:37 PM
Bill Dearborn's Avatar
Bill Dearborn
The tire diameters from front to rear have to maintain the same relationship as the stock setup. If you have TC on you probably have a slightly smaller diameter in the rear than you should have and that triggers TC at that speed. Turn off TC and see if it happens. The front to rear ratio is 1.0429 which is the stock rear diameter (26.7) divided by the stock front diameter (25.6). If your new tires have a smaller ratio than this there is a high likelihood the TC will trigger.
Bill
Old Aug 5, 2011 | 11:18 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
the sound barrier causes this. lol
Old Aug 6, 2011 | 01:42 AM
TMyers's Avatar
TMyers
Bill
Agreed, founds this out at the track. In my case it happens right around 100. I am .9 between frong and rear.
Old Aug 6, 2011 | 08:56 PM
gunone's Avatar
gunone
Bill
i really dont under stand the ratio but the front and the rears are 19 inch
Old Aug 6, 2011 | 09:25 PM
TMyers's Avatar
TMyers
Take your rear tire height and divide it by your front tire height. That will give you your ratio.
Old Aug 6, 2011 | 10:49 PM
gunone's Avatar
gunone
ok but i think they are the same
Old Aug 6, 2011 | 10:57 PM
gunone's Avatar
gunone
front 26 rear 26.5
Old Aug 6, 2011 | 11:03 PM
C7&7's Avatar
C7&7
Try what is stated above. Turn off TC and give it hell
Old Aug 6, 2011 | 11:08 PM
TMyers's Avatar
TMyers
Old Aug 7, 2011 | 11:42 AM
abstruse1's Avatar
abstruse1
No, no, you guys got it all wrong. It's the "Hoshit!" factor.
Here's how it works -- one's accelerating nicely, enjoying the scenery and eyeballing the tach, when all of a sudden, the speedo comes into view and the brain says "Hoshit!" and subconscious reflexes cause the right foot to lift. Then, the conscious mind takes over and says to put the pedal back to the metal (fiberglass?) and the car accelerates again.
As of this time, medical science knows no cure for this other than covering the eyes or the speedo. Most doctors advise the latter. Most funeral directors advise the former. Take your choice.
Old Aug 7, 2011 | 04:56 PM
gunone's Avatar
gunone
the only thing my brain is telling me is 200mph which is kinda hard when the brakes or traction control comes on.im really looking to solve my problem with this issue not wast my time with your b/s
Old Aug 7, 2011 | 07:59 PM
glass slipper's Avatar
glass slipper
While I understand your frustration with the problem you're having, I think you would do well to have a little sense of humor when you visit the forums here. Since you're still fairly new, think of the forums as the same place you'd be hanging out with your buddies drinking beer and talking cars...there's always somebody who's going to crack a joke and everybody laughs, has a swig of beer, and continues the serious discussion. Life goes a lot better with laughter and beer.
PS You never know, the guy above just might have the answer to your next question that nobody else gets...
Old Aug 7, 2011 | 09:11 PM
BigNY's Avatar
BigNY
This. While I'm as "boot" as it comes to this forum, having been a member to every message board to every hobby I've ever had, I can safely say that a sense of humor and a smile goes a long way on these kinds of sites. And near as I can tell, the ***** and giggles seem to be in no short supply here, as opposed to another website concerning a certain high performance GT car pumped out by a now defunkt GM subsidiary..... hope I didn't make that one too hard to figure out
Anyways, you should be driving with the traction control off anyways, electronic nannies are just that, nannies....
Old Aug 7, 2011 | 10:41 PM
el es tu's Avatar
el es tu
the front to rear ratio for the tire diameters is off. this cannot currently be reprogrammed to fix the issue. Supposedly there is a 3% tolerance for the difference, but I wouldn't put it that far. Try to get tires that have a diameter similar to or at least similar in ratio (front to rear) to the stock tires. otherwise the computer will kick in the controls and add the braking you are noticing. the comments about turning the system off are correct, but thats only a workaround. using the right diameter tires (not talking about the rim size - but rather the tire's outer diameter) is what is necessary.
hope this helps
To 150mph
Old Aug 7, 2011 | 11:12 PM
SoonerC6's Avatar
SoonerC6
Haha well done sir. ^^^
Old Aug 8, 2011 | 07:04 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Old Aug 8, 2011 | 07:49 AM
MARSC6's Avatar
MARSC6
Use this calculator to compare tires http://www.1010tires.com/TireSizeCal...?action=submit
Keep the ratio between front and rear as close to stock as possible.
