speedometer jumping
Old Aug 14, 2011 | 04:32 PM
bugsas99's Avatar
bugsas99
Default speedometer jumping
i am having rear differential replaced. ring and pinion going out. and now my speedometer is jumping around. i read where sensor for speedmoeter is on top of differential. anyone know how to fix this problem buy a new sensor???
Old Aug 14, 2011 | 05:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Most likely its just a bad connection. Take the connector off and spray it out with an electronics cleaner spray and put it back together.
Old Feb 18, 2012 | 01:55 PM
SnowyATX's Avatar
SnowyATX
Ever solve the problem? I have the same issue.
Old Feb 8, 2014 | 02:21 PM
Skip Ferrari's Avatar
Skip Ferrari
Default Same issue
My speedo jumps around as well & my cruise control won't stay on.
Anyone have a fix?
Old Feb 9, 2014 | 10:54 PM
TLTONEY's Avatar
TLTONEY
Old Feb 10, 2014 | 07:54 PM
SnowyATX's Avatar
SnowyATX
I guess I forgot to post my results. For me it ended up being the vehicle speed sensor on top of the diff. Could have been the cable harness being loose not sure. I doesn't cost much and can be done rather easily IF 1) you can get yourself under the car...safely and 2) contort your body around to get at it as it is on top of the diff.
Make sure not to push dirt back into the hole when installing the new one or drop the mounting screw into the diff.
To speedometer jumping
