May be looking into upgrading heads and a cam so which is it? Car will be used for mostly street and some track. Also looking to pass 500 rwhp 450 Tq. Car is an LS3 vette.
If you keep the car naturally aspirated, you will certainly need the following to get 500 rwhp in an LS3.
Headers (depends on the sound you want)
Exhaust (depends on the sound you want)
New Intake (suggest FAST)
New clutch
New rear end (not totally necessary, but recommended)
Cam (depends on sound and street manners you want)
Heads (lots of folks use Trickflow heads)
Most cam only upgrades should get you in the ballpark of 470-480 rwhp with supporting mods. A new intake would get you another 10-20, and so would new heads.
What kind of street manners are you looking for as this will dictate a lot about what type of cam to aim for?
New clutch
I've seen a few cam only LS3 (manuals) hit between 490 and 505rwhp and still remain quite streetable as well.
Cracking 500rwhp with a good heads/cam (along with the full supporting mods/bolt ons) package on an LS3 manual is quite achievable, Trick Flow heads or even a properly ported/polished set of LS3/L92 heads can help make it happen.
Call the guys at Breathless Performance since you live in Florida and work with them to get what you want.
I am doing a cam, rockers, CNC LS3 heads, FAST intake, ported throttle body along with the headers I already have and hope to get close to 500. I have an LS2, so you have 12 more inches displacement, so that should help you.
I would have to say advanced induction ls3 heads and a lg g6x3 cam. That package along with supporting mods will probably make over 520 rwhp and 480 rwtq.
A healthy cam, 1.875" Headers, Halltech 103 CAI, UDP and lightweight clutch should get you close to 500rwhp. If you are going to swap heads and intake I'd consider going to a cathedral port head as it will have better port velocity, allow more compression and have better PTV clearance allowing for a bigger cam than the LS3 heads.
I am not smart enough to debate this with you, but Wegner engines and one of the GM guys I know from GM Performance, both tell me that the best LS2 heads are not as good as LS3 heads.
Like I said, I am not smart enough to debate, I just asked them what to use, since I was upgrading, and both gave me the same answer. My GM contact is mentioned in almost every issue of GM High Tech Performance magazine and Wegner, until this year, built all the NASCAR LS spec engines for the regional series, so I took their advice. We will see the results of their recommendations later this month.
The current LS3 heads were the original LS7 heads, but they could not get to 500HP and meet all the other GM requirements without more cubic inches, so when the bore got bigger, so did the engines valves, thus LS7 dedicated heads. That is at least what I was told.
Call Horsepower Sales in Pompano, see my sig for the number. Ask for Jeremy or Roger.
They will get you there...this is what they do all day long for the S Fla Vette Community.
I agree with previous posters, cam, headers, intake...maybe heads if budget allows, but disagree that you need to swap clutch and rear, pending more information about how you plan to use the car.
I'm not here to debate with anyone, rather to inform The LS7 head did evolve from the L92 and notice it has a smaller runner yet flows much better. A small bore LS7 head would be another recommendation, but I haven't seen any results yet. I'm not saying the L92 isn't better than a ported GM cathedral port casting, I was referring to aftermarket cathedral port 235 TF, 230 AFR, 237 PRC.
100%
Since the fastest LS2s run a G6X3 and trick flow 225's at better than 520rwhp, I'd start there. The added displacement of the LS3 bottom end tends to show 15-20rwhp mod for mod so you do the math.
Trick Flows have huge decks, smaller combustion chambers for more compression, and have a better valve angle allowing huge cams without fly-cutting. They also have better resale value, and are way less fussy about cam profiles. Even the AFR 230V2 shares this lack of cam fussiness. Patrick G made 508rwhp on a 6 liter bottom end with a 231/231 114LSA with those heads. Thats a 3 degree overlap cam.
Why try to reinvent the wheel?
Get a G6X3 and trick Flow 235's. The bigger trick flow head fits the LS3 bore or an iron block with 4.03" bore and bigger. Its a >535rwhp result.
