Bellhousing Removal Help
Old Aug 25, 2011 | 02:50 AM
eguyett1985's Avatar
eguyett1985
Default Bellhousing Removal Help
I'm in the middle of a clutch upgrade on an 06 ZO6 and cannot seem to figure out how the bellhousing comes off. I removed all the bolts, tilted the motor back as much as I was comfortable with not hitting the firewall and even loosened the subframe bolts and lowered it slightly and still there just isn't enough room to get it out of the tunnel.
Is there something I'm missing here?
Old Aug 25, 2011 | 08:11 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
did you remove the two clutch slave bolts? the bellhousing to the trans or the bellhousing to the engine?
-Carl
Old Aug 25, 2011 | 10:34 AM
BEZ06's Avatar
BEZ06
The Service Manual says:
The upper bolts on the bellhousing can be accessed by lowering the engine cradle approximately 25mm (1 inch) and tipping the engine back
Did you lower the engine that much? It's still a tight fit, but can be done.
Good luck!
Bob
Old Aug 25, 2011 | 12:32 PM
eguyett1985
-Carl
Yes, I have removed all the bolts and now the bellhousing is not bolted to anything now, just the trans tunnel is keeping it from coming out.
Old Aug 25, 2011 | 12:33 PM
eguyett1985
Good luck!
Bob
I did lower the cradle down but maybe not an inch; I'll try that.
Thanks!
Old Aug 25, 2011 | 01:42 PM
Austin-vette's Avatar
Austin-vette
St. Jude Donor '08
I put a scissor jack with a 2x4 on it under the back of the oil pan and then removed all four nuts holding the front subframe on. Not sure the jack was necessary, but it made me feel better. I do not think the engine will drop more than a couple of inches with no jack and none of the nuts anyway.
Old Aug 25, 2011 | 04:51 PM
BEZ06's Avatar
BEZ06
Originally Posted by eguyett1985
.....just the trans tunnel is keeping it from coming out.
If by trans tunnel you're talking about the driveshaft support tube, it shouldn't even be in the car.
If you're talking about the area under the car, once you've removed the driveshaft support assembly, trans, and diff then there shouldn't be any problem removing the bellhousing.
To remove/reinstall the clutch you need to remove the driveline support assembly.
You did remove the transmission and differential from the car, didn't you?
It must be removed, or at least disconnected, so you can lower and pull the entire driveshaft/transmission/differential aft enough so the prop input shaft at the front of the driveline support assembly clears the engine flywheel housing (bellhousing).
Then you can remove the bellhousing and access the clutch assembly.
Bob
Old Aug 25, 2011 | 05:57 PM
eguyett1985
Bob
Yes, absolutely. The torque tube, trans, diff, and rear suspension are all out of the car at this point for other mods and maintainence. I'm going to try lowering the subframe some more and tilting the engine a bit farther at this point and see if that helps things. Because I'm going to start the ProCharger install after this, I'm wondering if it would be easier to just drop the entire cradle with the engine attached because it's up on my hoist anyway.
Old Aug 26, 2011 | 04:06 AM
Legal Alien's Avatar
Legal Alien
I am just about finished rebuilding my car after this very job, It is a struggle to get the bellhousing out but it is possible without dropping the front cradle. I did it on stands in the garage laying on my back, lots of fun!
I think I had to rotate it slightly as i pulled it away and then give it a good old wiggle. I did lay and ponder for some time because I also thought it was gonna be impossible to get it out. Despite thinking everything was clear it was constantly being caught on harness', clips and hyd pipes. Eventually though it came out and it also went back in!
Keep trying before anymore major surgery!
Old Aug 26, 2011 | 05:34 AM
SpinMonster's Avatar
SpinMonster
Tilt the motor forward by jacking up the rear of the pan. I lost count how many times I did this job and never once did I remove a cradle bolt.
Old Aug 27, 2011 | 12:35 AM
eguyett1985
I take it you first lowered the back to remove the bellhousing bolts and then tilted it forward to actually remove the bellhousing? I'm deep into just dropping the whole cradle with the engines for a variety of reasons that I'll go over in a new thread along with some additional questions. Thanks for the responses.
Old Aug 27, 2011 | 12:48 AM
fnsblum's Avatar
fnsblum
Are there any dowel pins like in days gone by? Later! Frank
Old Aug 27, 2011 | 01:10 AM
eguyett1985
Yes there are.
Old Aug 27, 2011 | 04:34 AM
TMyers's Avatar
TMyers
I lossened the cradle nuts so only couple of threads where left holding the cradle in. I had a bottle screw jack under rear of the pan to adjust angle. After I got the bell housing off the pins I twisted the bell housing to the right to get the starter bump pointing down then it came right out.
Old Aug 27, 2011 | 12:57 PM
fnsblum's Avatar
fnsblum
Yes there are.
Then you might have to pry it off like in days gone by. Later! Frank
To Bellhousing Removal Help
