Typical Adjustment Range for Rear Camber?
Old Sep 7, 2011 | 09:04 PM
RestoRoc89's Avatar
RestoRoc89
Default Typical Adjustment Range for Rear Camber?
Hello All,
I recently installed a Pfadt Johnny O'Connell suspension kit and lowered my car as far as the stock rear bolts would allow (lowered the front by an equivalent number of turns to maintain the amount of rake). After allowing the suspension a few days to settle, I took the car to my usual alignment shop and asked them to set the alignment in accordance with Pfadt's Performance Street specs. They managed to get everything pretty much bang on my targets except for the rear camber. With the lower rear eccentrics maxed out, I was only able to achieve -0.25 degrees of camber when I was targeting -0.5. I think this seems a bit off. The initial measurements before adjustment were crazy (-0.75 left, +1 right).
For those that have played with camber settings, what range of camber adjustment is considered normal for the rear on the C6 platform? I was expecting to be able to approach at least -1.5 degrees.
Thanks for you insight!
Old Sep 8, 2011 | 07:14 AM
el es tu's Avatar
el es tu
-1.2 is the highest the dealership techs have gotten the front (on my car)
-1.1 is the highest theyve gotten it to on the rear
Im running -1.0 front and -1.1 rear (not ideal settings from a performance aspect)
a few charts with alignment specs are available on this site. The amount of camber youre running is very low - you should have more than enough room to get to a higher range.
I think the best you can get it with factory adjustment is -1.2 to -1.3 front and -.8 to -.9 rear
from what Ive seen from people who race, as well as pfdat engineersing and from my own experiences, a 1.4 to 1.5 front to rear camber ratio is ideal (ie -1.5 front -1.0 rear)
btw I wouldnt let the car leave the shop until both sides were equal.
Having diff settings on each side is okay for driving on an oval or driving slow on the street, but is no good for "fun" driving.
Old Sep 8, 2011 | 09:19 AM
RestoRoc89's Avatar
RestoRoc89
Thanks for the input. Both side on the rear are now equal at -0.25 (limited by the RR side). Physically couldn't get any more rear camber than that. I'm starting to suspect the measurements because the car drove nicely with the wonky initial settings and it drives horribly now (steering wheel feels extremely light, car wanders UP the crown in the road and the back end feels too loose). Don't know what to do at this point other than call it a wasted effort and try another shop. I've used this one in the past and have been pleased with the results before.
Old Sep 8, 2011 | 10:26 AM
AU N EGL's Avatar
AU N EGL
Rear should be 1/2 of the front.
But no more then -1.5* IF your front is -3.0*
Old Sep 8, 2011 | 08:10 PM
RestoRoc89's Avatar
RestoRoc89
So is my chassis an oddball if I can't get anything more that -0.25 degrees of camber in the right rear corner? Is there anything I should check out that might be limiting my range of adjustment here? The shop has loosened the control arm bolts and rotated the eccentric adjuster to its maximum position.
Old Sep 8, 2011 | 08:18 PM
el es tu's Avatar
el es tu
Lets hope not. otherwise you might have a serious problem.
The control arms have spacers behind them. Removing or adding them changes the settings. Changes may have been done in order to get low camber for better tire wear.
Ride height can also come into play. Changing the ride height will affect how much negative camber you can get. If the car is higher than it should be, you could lose that useful range of camber.
Old Sep 8, 2011 | 08:28 PM
RestoRoc89's Avatar
RestoRoc89
I know the front control arms have spacers behind the bolts attaching the pivot points to the frame. The rear bolts go right through the pivot point though, don't they? I don't see how you could shim that out. This is a 2011 car with 3000km on it that I bought new, by the way. I've also lowered it as far as I could on the stock bolts.
Old Sep 9, 2011 | 02:47 PM
Streetk14's Avatar
Streetk14
I'm thinking the guy who set up the alignment machine didn't do it correctly. One of the sensors could have been crooked on the wheel, etc.
Pretty unlikely that a brand new car would be that far out, especially if you made equal adjustments to both sides. I do alignments as part of my job, fwiw.
I would get it rechecked as soon as possible, maybe at another shop.
Old Sep 9, 2011 | 02:49 PM
AU N EGL's Avatar
AU N EGL
Right rear is the difficult one
Look to see how many spacers are behind the screws attaching the upper A-arms to the frame?
Old Sep 9, 2011 | 06:12 PM
TMyers's Avatar
TMyers
This is correct for a non Z06 and maybe the grandsport. My max camber on the rear is 1.0. Remember that you only have one eccentric on the rear suspension. The rear lower control arm is fixed.
Old Sep 9, 2011 | 07:35 PM
RestoRoc89's Avatar
RestoRoc89
I just measured the camber roughly with a level in the driveway. I believe the alignment rack, the right rear wheel has next to no camber and the eccentric adjuster is pushing the lower bolt out as far as possible. To make the camber match on the left side, the adjuster is almost at its minimum setting.
I'm wondering now if it's possible that my diff crossmember is shifted towards the left side of the vehicle with respect to the frame. Anyone know how tight the locating pins are for that crossmember? Think it would move any if I loosened the bolts?
Old Sep 9, 2011 | 07:37 PM
RestoRoc89's Avatar
RestoRoc89
I have no recourse with GM, as the factory spec for FE1 rear camber is -0.45+/-0.60, but I'd really like to get more out of it and it sounds like most people can.
Old Sep 9, 2011 | 07:45 PM
RestoRoc89's Avatar
RestoRoc89
Thanks, this is the kind of info I'm looking for. I'd like to get a feel for how far out my car is from the statistical norm.
Old Sep 9, 2011 | 08:19 PM
TMyers's Avatar
TMyers
If you get the Pfadt camber kit you can get more out of it. It replaces the eccentric with plates. How much I don't know but I will be finding out this off season because -1.0 is not enough for r-compound tires.
Old Sep 9, 2011 | 09:19 PM
RestoRoc89's Avatar
RestoRoc89
I asked Pfadt about the camber kit and they said that you don't really get more adjustment, the square plates just eliminate the possibility of the eccentric slipping. Pfadt also told me that I should be able to get at least -2.0 in the rear when lowered. I think I could on the left side, but there's no way on the right. I'm looking into getting an offset control arm bushing made now.
Old Sep 9, 2011 | 09:34 PM
dbratten's Avatar
dbratten
The crossmember can be moved by loosening the four bolts that hold it. I used a large pry bar to shift mine and allow equal measurements using Pfadt camber adjustment plates. I wanted to use the same notch settings on each side which wasn't possible without moving the crossmember over. The front will also move.
Old Sep 9, 2011 | 09:41 PM
RestoRoc89's Avatar
RestoRoc89
You, sir, just made my evening! I'll try this in the morning.
To Typical Adjustment Range for Rear Camber?
Old Sep 10, 2011 | 07:27 AM
AU N EGL's Avatar
AU N EGL
No offense, but it your going through all this, may want to have the frame checked to see how true or straight it is.
You may be making more to do about nothing.
-.45* is just fine for normal street use of the rear, with -1.0* for the front.
Old Sep 10, 2011 | 09:56 AM
RestoRoc89's Avatar
RestoRoc89
No offense taken. Loosening 4 bolts and nudging a crossmember is about the easiest thing I could think of doing. With regards to -0.25 being fine for the street...how many of us bought Corvettes to just be "fine for the street"? I'd like to be a bit more aggressive front and rear, and want the flexibility in adjustment to track the car later on. If I'm not successful with this effort, I have no issues with checking the frame (and GM will hear about it). It really does look like the rear crossmember that's out though.
Old Sep 17, 2011 | 11:10 AM
raider4251's Avatar
raider4251
The rear sub frame pins are for installation and rough alignment. Further alignment is available for tuning.
