Differences in shifters?
My '05 C6 has 75k miles and the shifting is quite "notchy". I know that's a vague term, but it's not smooth like several other cars I have, including the old, reliable ZF6 in the C4. In some cases, it's difficult to get into gear at all, most often first or second. Fiddling around and shifting into another gear then back to first fixes it, but this seems wrong to me.
Does that sound like a shifter issue, or are my synchros going in the trans?
TIA
As far as I know the OEM shifters are the same through the C6 production. I think the ZR1 and Z06 have different mounting pads for the shifter's base, but the shifters are the same.No matter, the MGW is more fun, positive, and precise to use than the OEM version.
Tom
TIA
They wanted him to pay $275 a month to sell them. He refused so they banned him and deleted the thread.
I'm sorry about this rant, but this kind of short sighted treatment is what kills businesses. Just my humble opinion, and I'll probably get banned myself..but maybe someone with some business sense will read what I wrote and think about it...and put that thread back.
I have purchased from this sites vendors but I think its just dirty to delete posts if they are informative of ones experience with a product, good or bad.
mine was one of those post.
Thanks for the info.
When driving from a stop, I sometimes cannot put the car into first gear. I either have to double-clutch, force or shift to second then to first to get it into first gear!
Here's the answer now from my Dealer's Service Mgr.
-Bill. :bmad:
Document ID# 1690618
Intermittent Block Out of First Gear from a Stop - keywords hard no shift shifter stop #PIP3513 - (Aug 5, 2005)
2005 Cadillac CTS-V
2005 Chevrolet Corvette and SSR
2005 Pontiac GTO
Equipped with Manual 6 Speed (RPO - MM6, M10, M12 or MZ6) Transmission
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Intermittent block out of first gear at a stop. Driver may have the vehicle in neutral while stopped in traffic and when depressing the clutch pedal to engage first gear, the shift is blocked.
Recommendation/Instructions:
If this condition occurs less than 5 percent of the time, it would be considered normal. This condition occurring more than 5 percent of the time should be repaired. A clutching tooth improvement has been made to the first speed gear. Replace the first speed gear in the transmission. Check the gap between the vertical faces of the blocking ring teeth and the speed gear as per Document ID # 588712.
Transmission
Application
Part Number
MM6
Corvette
12455013
MZ6, M12
Corvette
88894089
M12
CTS-V
88894089
M12
GTO
88894089
M10
SSR
89059976
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Driver WT - my 05 would block out first gear all the time. My c5 did it too. When I had my transmission rebuilt it was built with the newer syncros and blocker rings and it's perfect now. Like night and day.
Pretty expensive fix though!
I have a great T56 rebuild shop in Fort Lauderdale if anyone needs one.
Would a 1-4 shift bypass effect this preload?
If my memory serves, there is a mod you could do on a C5 trans to reduce the 'notch-iness' of the shifter by spacing out a ball bearing that centers the shift rod in the gates. I don't know if you can do this on the T56 or 6060 in the C6's.
The shifter box bushings tear over time, causing play in the shifter. You can either try to find a 06 Z06 shifter box with sold brass bushings like I have (and love), or, you can buy replacement bushings.
Mez had a great thread on here about the problem with the bushings, with diagrams etc....I just searched for his thread, but looks like he was banned for selling the bushings to people and his thread was deleted. That's too bad...it was due to his research that I checked my bushings and my shifter woes were cured. I can see them telling him to stop selling or pay the vendor fee...but to delete his great thread isn't cool IMHO. Thanks again Mez if you're still reading the Forum.
Synthetic Fluid: Royal Purple, Amsoil or Red Line is what most people have used in here.
Ferrari and the like don't have to cater to soccer mom realities so their manual trannies just come with a precise shifter to start with. But GM (who does NOT have every car they make spoken for in advance) has to leave it to the aftermarket folks to fix things.
MGW does a good job of it. Had mine in there for three years now and I still enjoy it.
These things are just items of personal preference. They don't really make the car better or worse - just different. Some like, some don't. Some ask "why bother? it came with one."
Whatever.
Z//
For the record - I have been thinking about changing this fluid (approaching 27K miles but is 6 years old) and hope to do this near term. THANKS FOR Suggestion on types - I prob would have choosen GM. THANKS NS!
Others - MGW offers an additional lever to increase throw over their ST Version. It added nothing to shipping charges (Jul 11) to throw it in as an alternative so I picked one of those up too. (fwiw)
