Brake problem won't go away- need help
Old Sep 9, 2014 | 11:21 PM
  #61
Gering's Avatar
Gering
Tolero Apto Victum
Shoot this guy a PM - https://www.corvetteforum.com/forums...ne-culley.html maybe he can help you out.
Old Sep 22, 2014 | 04:39 PM
  #62
StKnoWhere's Avatar
StKnoWhere
Cut out the connector at the subframe and solder spliced the wires together, still have the problem but it seems better (takes longer to activate). Hub and harness are all new.
No codes after the car sits. The warnings activate after I drive 1-5 miles. Seems to occur when hitting a bump.
Guess the ECBM is next.
Old Sep 22, 2014 | 04:41 PM
  #63
cleanerPA's Avatar
cleanerPA
AH failures typical take a few miles to register because the fault has to happen x number of times over a certain mileage. You need a service manual and a Tech 2 to properly diagnose these issues, otherwise you're just shotgunning parts and $$$.
Old Sep 22, 2014 | 05:00 PM
  #64
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You still have the mechanical electrical MALE/FEMALE connection at the wheel Hub / jumper.
The ONLY way that you are going to know if you have a poor mechanical bond between the male pin and female pin is to do a PIN PULL TEST. Make/purchase or find a male pin the same size as the pin in the male WSS Sensor plug. INSERT it into the female pin. You MUST feel resistance on insertion and removal. If its LOOSE, the connection will be compromised upon each wheel vibration, bump or jar..
Bill
Old Sep 22, 2014 | 08:18 PM
  #65
StKnoWhere's Avatar
StKnoWhere
Bill
Thanks Bill, the hub and harness are new but I'll remove a pin from the old hub/harness and check.
Old Sep 26, 2014 | 07:50 PM
  #66
StKnoWhere's Avatar
StKnoWhere
The pins seem tight, I also re-oriented the connector but no change.
Strange thing now is I no longer hear the "ding, ding, ding" when it activates.
Old Oct 15, 2014 | 06:51 PM
  #67
StKnoWhere's Avatar
StKnoWhere
Problem found, harness was routed incorrectly during cam/radiator install and chafing against the steering rack causing intermittent LF Speed Sensor signal.
Wire repaired, harness routed to precent chafing and all is good.
Thanks again to all who offered advise.
Old May 20, 2016 | 12:32 PM
  #68
E39M5Speed's Avatar
E39M5Speed
Did you replace the harness? The part number I'm getting is 15248662. Is it easy to replace the harness for the speed sensor?
Codes I'm getting are C0040-00 and C0253-00 .
Right Front refers to Front Passenger side wheel correct?
