1/4 mile tires
Old Oct 6, 2011 | 07:09 PM
jjrctech's Avatar
jjrctech
Default 1/4 mile tires
what would be the different in time on a stock z06 1/4 mile from stock tires to slick tires???
does any one know the different in numbers
Old Oct 6, 2011 | 09:59 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Depends on how good or bad the driver was on the stock tires.
If you can't 60 on stock tires and run 2.2 60's then it'll make a HUGE difference and probably take off damn near a second if you cut 1.6 60's after the tires.
If you're cutting 1.70 60's on stock tires it won't make as much of a difference and you'll pick up a few tenths.
It all depends.
Old Oct 7, 2011 | 12:16 PM
PRE-Z06's Avatar
PRE-Z06
Default Here's some info
http://forums.corvetteforum.com/c6-z...fast-list.html
To 1/4 mile tires
