Should the MAF sensor be level?
Old Oct 8, 2011 | 04:02 PM
Turbooo2u's Avatar
Turbooo2u
Default Should the MAF sensor be level?
Took apart my VARARAM for a routine inspection and noticed the MAF sensor in the tube was not level with the ground but rotated about 40 degrees? Should I twist the tube to level it? This is on a Z06.
Old Oct 9, 2011 | 02:27 AM
tjwong's Avatar
tjwong
Doesn't matter to the sensor what position it is in. I usually mount it so that its on the horizontal plane with the inlet tube or coupling just for asthetics.
