High Beam / Turn Signal problem
Has anyone with a non-telescoping steering wheel replaced this switch without removing the steering wheel? Is there enough clearance to get the covers off with a fixed wheel that can't be "pulled" to full extension?
Also, if the steering wheel doesn't have to be removed, does the airbag still have to be disabled?
thanks,
jer
Yes you can replace this switch with a manual (non-telescoping) steering wheel without taking the steering wheel off.
I just did.
Also, I took my chances and did not disable the SIR by disconnecting the battery per manual instruction because I wasn't removing the steering wheel...although I'm not sure this is safe. Maybe the airbag could deploy by making and breaking combo switch connections with hot elects...don't know but I was ok. No guarantee for your experience.
Note: Although I tried to "use a small screw driver and release the locking tab from the tilt wheel handle" per manual instructions, I couldn't figure where this locking tab was or how to pull the handle out. But when I removed the knee bolster and the instrument panel bolster bracket I was able to twist the lower column trim panel off the tilt wheel handle still installed. Without damage. So you don't have to remove the tilt handle if you can't do it.
Nice to have a blinker that works w/o blinding the driver in front. Or flashing them with on and off brights as you try to finesse the switch into the low beam position. Dealer quoted $400 for the job so saving about $360 w/ a couple hours of work.
Trust me, unless you experience this switch failure, you won't know how annoying it is. Think driving at night and unintentionally flashing your brights to the driver ahead just trying to signal a lane change. They think you're annoyed or alerting or just being an a**hole.
Think signaling left lane change because a cop pulled someone over on the right. Instead you turn on your brights. And then flash him on and off because you're just trying to turn your brights off.
Not cool! I've done both with this bullsh*t combo switch failure.
And this is a common failure mode with the switch as it has been for a long time. I'm pretty sure this switch is also used on gm cars other than the corvette. GM needs to fix this with their supplier.
Maybe (long past) time for a better design??
jer
So, this seemed all simple, especially since the part was only $30 on Amazon (prime woo).
I followed the instructions, except there were a few details left out that I had to venture out to find...
1) Disconnect your car battery first.
2) You will need to remove (gently) the airbag center piece out of the steering wheel (Youtube I found of someone doing this in a 1m 27sec timeframe:
3) Dettach the airbag wires (pop the small plastic pieces upwards then pull off the wires).
4) Then be like "OMG the airbag on the vette is so cool, this looks like a superman symbol!".
Now here's where I screwed up, I was told to remove the WHOLE steering wheel. I do not have a 21mm socket wrench (HUGE).
Solution:
5) There's a tiny hole (big enough to get a flat head screwdriver) which sees through directly to the star screw where your blinker is that you need to remove). I was able to unscrew this screw, and then unscrew the one from the top, and remove the left steering switch (blinker/headlights).
Once you get it off there, it might be nice to clean up a little bit, maybe some compressed air, it probably has all sorts of nasty stuff in it.
Take your time when you are working with the harness. I did NOT have to remove the entire harness. Once I got the blinker off the column and unplugged, it was easy as putting the new one back on and reassemble the steering column WITHOUT taking the whole wheel off.
Hope this helped someone
For a bit mine were a bit crooked, but I was able to get them back to normal. This will be 90% of the time you spend on this project unfortunately. Chevrolet didn't plan on anyone removing these parts, I'm guessing they thought the vehicle would last the full lifetime of the car, as is most of the other inconvenient parts placed throughout the car like the oil sensor -.-
Good luck, and thanks for starting this thread!
Quick question on this topic: I have a 2006 C6 with the telescopic steering wheel, and need to replace this lever because I'm flashing drivers at night when I use the turn signal.
I see conflicting information in this thread and another thread as to whether I can get the cheaper part # D6244E or whether I need the more expensive D6384D because of the telescopic wheel.
I do not have rear fog lights (I don't think), since I'm in Los Angeles and not Europe. Anyone know for sure if the cheaper one will work fine or not?
