Socket for axle nuts
Old Nov 29, 2011 | 12:25 AM
Rebel 1's Avatar
Rebel 1
Originally Posted by Gearhead Jim
You can use the link from Rebel 1 and see the old version of the bulletin, note that it has the incorrect torque value and the part # for the nuts may have changed again.
Your dealer can also print it and do the work for a price that may or may not be a good deal.
Jim, I have found that TSB #07-04-95-001 is the current doc. dated 10-1-2007.
Everything i have found on this lists 160 ft.lb. torque for axle nuts.
If this number is incorrect, i and probably others would like to know.
Bob
Old Nov 29, 2011 | 03:23 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Bob
So would I!
I thought I knew, but now I don't.
Perhaps someone can have their dealer look up the bulletin and print out a copy, or at least verify the torque numbers.
Old Nov 29, 2011 | 05:54 PM
Cherokee Nation's Avatar
Cherokee Nation
Yes it is.
I Checked Corvette Web Central.com and it shows TSB #07-04-95-001 as the current document for Corvettes.
It is dated Oct.1,2007. 160 ft.lb. torque value for axle nuts.
Bob
Thank you Sir
Old Nov 29, 2011 | 08:56 PM
Rebel 1's Avatar
Rebel 1
Originally Posted by dardenken
Thank you Sir
Old Nov 29, 2011 | 10:31 PM
Gearhead Jim
St. Jude Donor '13
Yes it is.
Bob
I hope this is true, but since that isn't an official GM site-
They might not have the latest bulletin, a problem I have seen before.
I'm too lazy to go to the dealere right now.
Old Nov 30, 2011 | 01:23 AM
Rebel 1's Avatar
Rebel 1
When i go to the dealer about a TSB or a problem they look at me like a deer in headlights!
Old Feb 3, 2025 | 10:45 PM
Shy Jackson's Avatar
Shy Jackson
1st Gear
Default 33mm axle nuts work
Hey guys, I have a 2011 corvette grandsport, 33mm deep socket is what you need for the axle nut.
Old Feb 4, 2025 | 12:16 AM
Dano523's Avatar
Dano523
Our cars:
2006 = 33mm
2009 = 34mm
This, since if car is older, will need 33 to remove the old nut,a nd new replacement nut is going to 34mm instead.
But if you check with an auto parts store around you, should have the free loner tool program for both size sockets, since may never need the sockets for decades again.
