saving power
Old Nov 29, 2011 | 08:18 PM
CleoLee's Avatar
CleoLee
Navigator
Default saving power
I have a 2007 Z06. During the winter, I'm not likely to drive the car a great deal, and I don't want the battery to die. I've heard that while a battery manager can help in this regard, they can be dangerous because they can sometimes overcharge a battery and cause an explosion. Can someone help me with thoughts and/or ideas on this subject, please? Thanks, Tony.
Old Nov 29, 2011 | 08:35 PM
JoesC5's Avatar
JoesC5
I have four of the Harbor Freight float chargers that usually run around $10-$12 but are on sale all the time for around $6. I keep them on my 56 Vette and my 64 vette year round and on my mower during the winter(5 months) and on my 09 Z06 when ever I'm not going to be driving it for at least 3 weeks. No blown batteries in the past 8-10 years I've been using them.
But, I've found that they do not work very well if you forget to plug them in.
Old Nov 29, 2011 | 08:45 PM
WNDOPDLR's Avatar
WNDOPDLR
I, too, use the HF chargers and have them on multiple cars and motorcycles and a standby generator. No problems for 4+ years.
Old Nov 29, 2011 | 11:43 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
CTEK, Deltran and Schumacher all make Battery Tenders that will safely maintain your battery without overcharging it.
You can even get one from CTEK with a Corvette logo on it if you want to pay extra.
Old Nov 30, 2011 | 01:34 AM
CleoLee's Avatar
CleoLee
Navigator
Thanks for the responses. That's helpful. I'm just a little concerned about plugging something into my car that might cause the battery to blow up like I've heard. I'll probably look into the companies you folks recommended. Thanks again.
Old Nov 30, 2011 | 02:21 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I have a Deltran and it's very nice. I use it to charge my C6 and my Lotus Exige S.
The Harbor Freight charger I picked up specifically stated it was not to be used with AGM batteries. I gave it to a friend.
San
Old Nov 30, 2011 | 03:09 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I use a BatteryTender Plus on my C6 whenever it is going to sit for more than a couple of days. It's built to not overcharge and shifts to a trickle maintenance charge after it has charged the battery. I never had any problems with it.
Old Dec 3, 2011 | 02:37 PM
CleoLee's Avatar
CleoLee
Navigator
A mechanic I trust suggested/recommended a Battery MINDer charger/maintainer. I would really like to avoid going through the hastle of resetting all the electronics, but he suggested unhooking the battery when putting it on the charger/maintainer. For those of you who use this kind of device, do you leave the battery hooked up to your car while having it on the maintainer, or do you unhook it? And with my Z06, the battery is in the back. The car's handbook states that when charging the battery (if it goes dead), you're suppose to hook up the battery cables to another place under the hood that is covered by a plastic enclosure. Should I hook the maintainer up to the battery directly, or where I would hook it up if "jumping" the battery when dead? Thanks.
Old Dec 3, 2011 | 03:00 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
I have a Battery Tender. I leave it connected to the car for months in the winter. I never take off the battery cables. Has been good for the past five yrs
Old Dec 3, 2011 | 03:09 PM
CleoLee's Avatar
CleoLee
Navigator
Thanks, Driver. What about where to hook it up? Since the proper way to jump the batter is to hook up the battery cables to the other spot under the hood, rather than the battery, is it better to hook the maintainer up to the battery directly, or to where you would hook the battery cables when jumping the battery when dead?
Old Dec 3, 2011 | 03:20 PM
JoesC5's Avatar
JoesC5
Under the hood, on the driver's side, there is a fuse box. Connect the red alligator clamp from the float charger to the large lug under the fuse box lid, Then connect the lack alligator clamp to the frame ground attachment point that is located between the fuse box and the oil reservoir. Then plug the float charger in. Don't close the hood all the way, let it rest on the springs. Next time you go to drive the car, the hood being partially raised will remind you that the float charger is connected.
You don't need to access the battery in the rear to connect the float charger.
Old Dec 3, 2011 | 06:29 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
I have a C6 coupe, not a Z06, so i just connect directly to the battery posts under the hood.
Old Dec 3, 2011 | 08:36 PM
Olddudesrule's Avatar
Olddudesrule
I've used Deltran Battery Tenders on all my non-daily driver cars and motorcycles for the last 15 years. You have absolutely nothing to worry about hooking your car up to one. It is an extremely low amp charger, and will not over charge any battery. I have the Z hooked up under the hood, as has been described above. It will take 10 minutes to do, and you're ready to go.
To saving power
