Battery Truths
Old Dec 23, 2011 | 05:13 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Battery Truths
Is it true that once a battery goes below 12 volts the battery is junk?
It's been my experience that once a battery will no longer start a car it is a goner no matter the age of the battery. I've never been able to get a battery to hold a charge once it goes bellow 12 volts.
That being said, my 2 year old DieHard just died. Sears tested it and said that it was fine! Pumped a quick charge into it and sent me home.
I don't trust this battery anymore. Should I?
Tom
Old Dec 23, 2011 | 05:24 PM
timd38's Avatar
timd38
We make over 100M car batteries a year. I can't talk about cam spec's but batteries I know.
The average flooded battery in a car is not made to take deep discharging. 12 volts is OK, but if you get below 10 you start to damage it. A battery is fully charged at about 13 volts. Unless the battery was discharged for a long period of time at low voltage, I would not worry about it.
Old Dec 23, 2011 | 05:30 PM
Snug's Avatar
Snug
I purchase non-working riding mowers and fix them up as a hobby. Many times I've picked up a mower with a battery indicating less than 12 volts. An over-night charge on the old trickle-charger brought them back to life. Of course, that's not true all of the time.
I would think a two year old Die Hard would be just fine after a good charging.
Old Dec 23, 2011 | 08:06 PM
needcheese's Avatar
needcheese
I always try to do a trickle charge on a low or dead battery. I try to stay away from a quick charge. A battery sides that are expanded is normally not a good sign. I have had them last a few years once expanded.
Old Dec 24, 2011 | 11:38 AM
REVAK's Avatar
REVAK
Tom
One exception on a partially or fully discharged wet cell battery. If the battery is exposed to temperatures below freezing while in a discharged state, then they are junk. Also if the battery is quick charged or over charged , [ internal temp. exceeding 125* F], then they are also junk.
Old Dec 24, 2011 | 12:43 PM
JoesC5's Avatar
JoesC5
To me, convenience is a major factor in my decisions. Finding your battery dead is inconvenient, especially if you are in a motel parking lot on a Sunday morning hundreds of miles from home(even worse if the wife is with you).
For $120, get a new Duralast Gold from AutoZone and then put it out of your mind.
Old Dec 24, 2011 | 02:39 PM
speedwaywhite's Avatar
speedwaywhite
Conventional 12 volt batteries are 2.1 volts per cell when up,( 12.6 volts is charged,12 volts indicates a discharged battery). I agree with the slow charge method with this exception: a battery that is deeply discharged may need a high rate of charge for the 1st hour to overcome the internal resistance, after first hour cut back to 10 amps or less rate of charge.
Old Dec 24, 2011 | 03:10 PM
TCW's Avatar
TCW
So you like the Duralast, Joe? I looked at those the other day.
Tom
Old Dec 24, 2011 | 03:36 PM
JoesC5's Avatar
JoesC5
Tom
I have one in my supercharged Mercedes(half the price of a M-B battery) and it's been doing great for the past 4 years. I also have them in my 56 and 64 vettes which very seldom get driven(kept on a float charger all the time). They have both been in for around 6 years with no problem. I let the OE Delco batttery die on my 09 Z06(forgot to plug in the float charger after I unplugged it to plug in the air compressor to air tires(my bad)). It charged up, but I'm going to replace it with the Duralast Gold in the Spring, to ward off any potential problems, if it is weakened.
Old Dec 24, 2011 | 05:26 PM
el es tu's Avatar
el es tu
If you want a low weight replacement look up deka. They make batteries that are super lightweight but low cost (less than 100 bucks).
Old Dec 24, 2011 | 06:08 PM
JoesC5's Avatar
JoesC5
With all the money GM spent to reduce the weight on the Z06(and the extra money the consumer has to spend to purchase a new Z06 over the heavier base/GS C6), and all they had to do is spend another $25 and save 15 lbs using a deka battery, they would have done it in a heartbeat.
There must be a good reason GM didn't feel that the cheap way to reduce 15 lbs was not cost effective.
Old Dec 24, 2011 | 08:32 PM
ILLUSHN's Avatar
ILLUSHN
Good man! I just installed one of these on Thursday!
The original was installed in August of '07. I drove it on Sunday and when I came out on Monday it was dead. At first I thought it was the fob battery, because it let me in the car and I was getting a 'no fob' message on the DIC.
The next day I replaced the fob battery and it wouldn't let me in. So I bought a new battery the next day and it started right up!
Turns out that there was a powdery build up on the negative cable that I never saw because of the plastic cover on it. I'll be more vigilant from now on.
Old Dec 25, 2011 | 11:46 AM
Streetk14's Avatar
Streetk14
Tom
I guess the real question is "why did it die"? Probably an underlying reason for it, at least based on my experience as a Technician. Sometimes batteries do have a cell fail, and in that case they will only hold about 10.5 volts.
But yes, when a battery gets below 12.0 volts, it has been proven to reduce it's life span and cause early failure. This has been a big issue and some of the OEMs have been putting extra effort into making sure batteries are properly maintained in new cars that are in dealer inventory. Voltage should be kept at 12.5 volts or higher for the best battery life.
For what it's worth, here's a chart of voltage vs. charge % :
12.65 V = 100%
12.45 V = 75%
12.24 V = 50%
12.06 V = 25%
11.89 V = Discharged
My experience and opinion is that once a battery is discharged, it's never 100% again. I'd replace it if I were you, even if that means buying a new one yourself. Then I'd do some amperage draw testing to see if you have something abnormal going on that is causing the battery to drain. If everything checks out normal, get a battery tender to help protect the new battery and maintain proper voltage.
My opinion at least
Old Dec 25, 2011 | 12:48 PM
el es tu's Avatar
el es tu
its pretty obvious that the smaller battery will die quicker than a 30 to 40 lb brick. But at 80 bucks apiece, who gives a damn? For 20lb weight savings off the front end its worth it.
Old Dec 25, 2011 | 03:21 PM
TCW's Avatar
TCW
I probably let it sit to long without driving it. I'm pretty sure it sat for 6-7 weeks. I normally drive the car at least 100 miles a month, but for various reasons haven't drove the car lately.
Tom
Old Dec 25, 2011 | 05:18 PM
Bill Dearborn's Avatar
Bill Dearborn
Just because it has been completely discharged doesn't mean it is bad. Have had many batteries that I accidentally discharged to the point the horn wouldn't blow and the lights wouldn't light and was able to charge them and use them for years after the discharge. In the old days before we had automatic warning of the headlights being on it was a lot easier to leave the head lights on all day and run a battery completely down.
Bill
To Battery Truths
