Removing ECU
Old Feb 12, 2012 | 03:14 PM
blueyeszr1's Avatar
blueyeszr1
Account suspended by request 6 Oct 2017
Default Removing ECU
I am removing the ECM and I am not sure how you remove the 2 wire plugs. How do you get these out? Help Please
Old Feb 13, 2012 | 02:47 AM
hefti2's Avatar
hefti2
There is kind of a lever at the back of each of them. You have to lift those up , then the connectors will lift up at the same time.
The lifters are secured, hard to describe. Look at it and it should be obvious.
Hope that helps.
