Idle Behavior -- Modded LS2
Old Mar 12, 2012 | 05:29 PM
sallen619's Avatar
sallen619
Originally Posted by DannyBoyC6
Quick question -- while I was cleaning the throttle body with carb cleaner, I noticed that the blade doesn't sit all the way closed at the ridge line when disconnected --i.e., the blade can be pushed wide open AND can go back a 1/2" to the ridge where it's fully closed off. Can anyone confirm that's normal?
Thanks!
Mine does the same...
Old Mar 12, 2012 | 05:48 PM
DannyBoyC6's Avatar
DannyBoyC6
Originally Posted by 1fastbob
If you don't get a reply, I have an extra throttle body at home I will check out in about an hour and a half when I get off work and I will let you know.
Thanks a lot -- looks like I have an answer though.
Old Mar 12, 2012 | 05:49 PM
DannyBoyC6's Avatar
DannyBoyC6
Good to know. I guess I'll button it back up with a newly cleaned MAF, TB and air filter, then see if the dreaded "idle problems" are fixed.
Old Mar 12, 2012 | 05:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by victorf
Carb cleaner is an old school favorite and more friendly overall! As mentioned, still flammable, do use with caution!
WHAT???
" Originally Posted by victorf
FYI. Free internet information is not Gospel, need to take it with a grain of salt from "Experts". "
Brake cleaner is highly flammable, spraying indiscriminately on an running engine is unsafe, catastrophic with an unintended spark and is detrimental on rubber parts nor friendly to electrical components around engine compartment. Use can do more harm than good.
Chemicals have unique application. Read manufacture's directions and warnings.
QUOTE"
"Carb cleaner is an old school favorite and more friendly overall! As mentioned, still flammable, do use with caution! "
CARB CLEANER!????????????????? REALLY?? Its a whole lot less plastic part friendly (read MELT some plastic parts ) its a whole hell of a lot more flammable!!!!!!!!!!!!!!!
Jesus Christ.
If you want to do it WITHOUT SOLVENTS, grab a propane torch and use the GAS (NOT LIGHTED) around all the possible air leak areas. If theres a leak, the ingested gas will cause an improvement in idle quality. OH,, BE CAREFUL<<<<< THAT GAS IS FLAMMABLE!!!
Someone needs to REEXAMINE their rational..AND EXPERT RECOMMENDATIONS......
BC
Old Mar 12, 2012 | 06:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks!
COMPLETLY NORMAL. WHEN YOU TURN THE IGNITION ON, IT WILL ERRECT ITS SELF TO THE LAST KNOWN IDLE POSITION OR DEFAULT TO THE FACTORY SET POSITION AND IDLE RELEARN FROM THAT POSITION. Sorry for the CAPS.
Old Mar 12, 2012 | 06:36 PM
1fastbob's Avatar
1fastbob
Jesus Christ.
If you want to do it WITHOUT SOLVENTS, grab a propane torch and use the GAS (NOT LIGHTED) around all the possible air leak areas. If theres a leak, the ingested gas will cause an improvement in idle quality. OH,, BE CAREFUL<<<<< THAT GAS IS FLAMMABLE!!!:*****:
Bill, Careful...you are going to blow him up.
Old Mar 12, 2012 | 06:58 PM
C7&7's Avatar
C7&7
Yeah this is just a tuning tweak. It will be related to clutch fuel cutoff and the air flow table in neutral. Just a tuning modification. Odds are it's nothing serious.
Old Mar 12, 2012 | 09:37 PM
DannyBoyC6's Avatar
DannyBoyC6
I checked the O2 sensors, cleaned the MAF sensor, cleaned the throttle body, air intake filter, checked for leaks along the intake path, and nothing has changed for the better, so I tend to agree. It's that or a mystery vacuum leak -- but I don't know where other than along the intake to check, so probably not worth checking without some assistance from a more knowledgeable car guru.
Old Mar 12, 2012 | 10:56 PM
victorf's Avatar
victorf
WHAT???
QUOTE"
Jesus Christ.
BC
Sorry my posting upset you! But certainly enjoyed your colorful and "CAPITALIZED" response! Its all good!
I could be wrong, over time, I have found my preferences. My posting was to remind those just starting out, to read warnings on chemicals and not to take posting as gospels, of course, thats including mine.
The good old potent Carb cleaners were too hazardous and non available locally. Today, we have in its place, milder "Carb & Throttle Body" cleaners. I do prefer "propane gas" primary, but in a pinch, I prefer the modern carb cleaner, spray in specific area for vacuum leak check and not in painting the engine fashion. Using precautions and small focused quantity, there is little cause of harm!
When comes to Brake Clean, there is one that is less potent, that is the one I prefer to use primary for what it is formulated for.
From this postings, you probably can tell where I stand when comes to using chemicals.
I hope I didn't pi$$ed in your parade and your "BLUE SUEDE SHOES" are pristine!!
