Check engine light
Old Apr 6, 2012 | 07:50 PM
06BlackC6's Avatar
06BlackC6
Default Check engine light
Ive had my ls2 C6 for about a week now. I took it to the car wash today and sprayed it off, while driving it home I noticed the check engine light come on. I was wondering what might be the cause of this, I don't have a way of hooking up to it yet to check for trouble codes. Any help is greatly appreciated. Car still runs and idles great.
Old Apr 6, 2012 | 07:57 PM
C6topless's Avatar
C6topless
Ok here is what you should check if the light continues to be on..... Check the solinoid for burn spots or cracks on the terminal ( they are prone to failures ... If it is bad, swap it out .. Do not buy a full starter unless you want to waste money) ... Next your alternator ... See what Amps it is pushing out ( personally I would swap it out to a higher amp one as the stock is barely adequate ) and finally load test your battery.... I think you will find your problem in one of these 3 items.
Old Apr 6, 2012 | 08:07 PM
DSOMC6's Avatar
DSOMC6
Could be related to water intruding somewhere or perhaps just a coincidense.
Without a scanner to read the code you are pretty much SOL. Owning one of these cars out of warranty eventually requires the purchase of a basic Can2/OBD scanner or paying a mechanic to troubleshoot issues.
Old Apr 6, 2012 | 08:12 PM
EVRose's Avatar
EVRose
Check your gas cap. When you screw it on do not apply any pressure on it. Just turn it till it clicks a few times.
Old Apr 6, 2012 | 08:33 PM
06BlackC6's Avatar
06BlackC6
Thanks guys for the help and quick responses.
Old Apr 6, 2012 | 09:21 PM
VET4LES's Avatar
VET4LES
Did you spray the engine? If so I wouldn't do it again. Some auto shops will check the codes for you. Usually they don't charge for it.
Old Apr 7, 2012 | 04:05 PM
bezzy1785's Avatar
bezzy1785
my check engine light also come on n off but i have scann it several time and is saying banks 1 and 2 running rich i think is my o2 sensor.... anyone have good reference about this issue...btw have anyone had issue starting ur vette please let me know thanks...sorry was not trying to jump off topic......
Old Apr 7, 2012 | 04:35 PM
ChevyDave's Avatar
ChevyDave
It helps alot to have the actual codes , letter & 4 numbers for all that were found. Really can narrow down to best solution that way.
To Check engine light
