how much will z06 wheels stick out on a base model without the wide body. For that matter are the GS front fenders wider than the base ones? I think they would look great on my base model...
man I wouldnt think them big ole things would be goin under the stock qtrs /fenders--wouldnt they hit the fenders on a sharp turn?? what would that do to the rear if you hit a good bump / hole?
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
GS/Z06/ZR1 all have the same dim. on the body fitment.
Those wheels would be 1.5 to 2" outside of the body of a narrow body car.
I would suggest you consider a set of quality lightweight wheels with the proper offset that will reduce your rotational weight and allow you to run wider tires. I'm assuming you're after performance since you're posting in this forum.
