diff noise gone
Old Jun 7, 2012 | 07:18 AM
GOLD72's Avatar
GOLD72
Originally Posted by ELP_JC
Hey, have you done the cooled differential (GS) according to the service manual? It requires running the car at 'x' rpm in 2nd gear, or something like that, then shut engine off and immediately fill again until fluid comes out. I don't know how much more you can fit, due to cooler volume. Curious about your comments on that. I plan to do it by the book, which requires putting car on ramps in front and stands on rear (I already did that when swapping my '12 catted X-pipe with an '11 non-catted (OEM) one. Thx.
Yes, I have on my 06Z and it wasn't fun per the shop manual. After doing that run procedure and all the banging and clanging of the rear axles, the diff will take a few more ounces. If I ever do a diff fluid change again though more trouble, I will just drive the car down the street a hundred yards and back and then relift the car and top off the diff. JMHO though.
Old Jun 7, 2012 | 04:04 PM
JCtx's Avatar
JCtx
Originally Posted by GOLD72
If I ever do a diff fluid change again, though more trouble, I will just drive the car down the street a hundred yards and back and then relift the car and top off the diff. JMHO though.
I'd do the same with a lift, but the way I have to put the car on the air, would take way too long. However, the better question is how much more can you pour if you shut off engine right away, or if you wait an hour or more. Hmmm. Maybe it's minimal. But I'd definitely top it off one way or another. Manual says to top off right away after shutting engine off. The way I level my car on the air, with ramps in front and jack stands on rear, I'll definitely start it on the air, but without getting inside the car. Hey, does the drivetrain really clunk that bad? It shouldn't hurt anything even if that's the case; otherwise it wouldn't be recommended IMO. Thanks man.
Old Jun 7, 2012 | 08:55 PM
SudburyC6's Avatar
SudburyC6
well my 2009 Z06 just had the new diff fluid done today and it still grinds/clunks after fast takeoffs...straight line...any TSB on clutch pack replacement?
Old Jun 8, 2012 | 07:02 AM
GOLD72's Avatar
GOLD72
Probably doesn't hurt the power train over such a short duration but it is disconcerning none the less. Running the back wheels for a minute I think is to let the recirc pump and cooler system fill back up if it self drained some during the main housing drain. I don't remember it taking more than 3 or 4 ozs to top off after the running procedure so not much drains from the cooler circuit.
Old Jun 13, 2012 | 03:37 PM
Jharms's Avatar
Jharms
... If you try it, give us a report.
I replaced the fluid that the local Chevy Dealer put in a couple of weeks ago (at about $100) with AMSOIL (at a DIY cost of ~$40) and so far, so good! Mine was chattering very severely and I really thought there would be no hope without replacing parts. Too early to tell if this is a long term fix for my 2007, but I'm certainly encouraged.
Thanks, Subdriver for the price break on the product. It was delivered fast and the stuff works like a champ!
Old Jun 14, 2012 | 10:34 PM
gsflyer2011's Avatar
gsflyer2011
Stationary, rear raised, mine did not clunk at all, it was almost as smooth as driving it on the road. By the way, it is in second gear, 10 MPH for one minute. Make sure you turn off the traction control (that will create lot of banging), and release the Ebrake...
Old Jun 14, 2012 | 11:21 PM
JCtx's Avatar
JCtx
Thanks for the heads up on TC man . That's probably what happened to Gold72. In fact, 'active handling' might also be the culprit since front wheels don't turn, so I'll switch AH off altogether before engaging 2nd. And 2nd gear at idle is pretty much 10 mph, so no need to give it any gas. Thanks again buddy.
Old Jun 16, 2012 | 09:37 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks and my pleasure.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
