E-85 question on heads cam car
Old May 31, 2012 | 06:41 PM
U Lost's Avatar
U Lost
Default E-85 question on heads cam car
I have a heads cam LS3 A6 that put down 484rwhp and 446rwtq
The heads are PRC 250cc aftermarket castings milled to 11.25 to 1
cam is a 225/230 on a 114. and I have all the supporting boltons
vararam, ported fast 102, NW 102tb, LG superpros, no cats, LG GT4 catback and slp underdrive pulley.
I have read the thread where the guy put E-85 in his stock car and tuned it to pick up really good power. Now i know some of that was the tune. I know i need bigger injectors to run the E-85. The car is not a dd so i do not car about the gas milliage.
Does anyone with any expierence with E-85? or a tuner think it is possible for me to get over 500rwhp with just a gas change and a retune? I saw how much it did for that guys stock car and i was wondering what it could do for a fully built N/A application. I know it does more for boosted cars but that thread really has me thinking
any help or advice is appriciated.
Old May 31, 2012 | 06:58 PM
ashanson's Avatar
ashanson
I would say it's pretty easy to pick up 16rwhp with a switch to E85 at that level N/A. You can add timing through the roof. All of my experience with E85 is with FI though, and I picked up over 50rwhp when switching.
I love E85, but I wouldn't make the switch if I was N/A unless it's really hot where you live and don't have any good premium. I only have 91 here and it's not that great, so the choice was easy for me when I added the blower.
Edit: what kind of timing does your tune have right now?
Old May 31, 2012 | 07:26 PM
U Lost's Avatar
U Lost
I think the timing was around 22 or 23 degrees cant remember for sure though
Old Jun 1, 2012 | 09:50 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
You will need 60# injectors. The Siemens ones are 60# at 43.5#s of rail pressure IIRC. E85 loves high compression.
Since you have a LS3 your pump should be fine, but a BAP is likely a good idea.
Old Jun 1, 2012 | 10:28 AM
C7&7's Avatar
C7&7
Bigger injectors will be a must, along with a new tune. You will get to 500 I am sure. Gas mileage will be alot worse though.
Old Jun 2, 2012 | 01:33 PM
Kerrdogg's Avatar
Kerrdogg
We have been playing with e85 for a few years now, on my sales guys Trail Blazer SS he saw about a 30 rwhp gain, sure mileage drops but the fuel is usually 25 - 30% cheaper than premium so cost is a wash. Turbo cars love it, we are breaking parts that normally don't break due to HG failure, but on e85 the HG's don't fai. Get a couple of spare fuel filters and change them often if you make the switch, e85 will clean the fuel system well and plug the filters easily. After a few filter swap outs you should be good to go, of course the newer the car the less crap in the system.
Old Jun 2, 2012 | 10:55 PM
PRE-Z06's Avatar
PRE-Z06
I'm not sure you'll make 500rwhp with just the switch, because your DCR isn't crazy high and you already run a decent amount of timing as the LS3 heads are efficient and don't require a lot of advance. It will help the car run a little cooler and that could help make a little more power, if you're just looking for a dyno number throw on an EWP and drop the belt for a lot cheaper...
To E-85 question on heads cam car
