C6 Leaf Spring Identification
Old Jul 16, 2012 | 10:16 AM
Shifter6's Avatar
Shifter6
Default C6 Leaf Spring Identification
I picked up some used leafs a while ago and want to confirm what they are before I install them. I figured you guys would be able to help with this. There are two numbers, one engraved/molded into the spring and one on the sticker with the bar code, I listed both below.
Front: Engraved 22171750, sticker 22178729
Rear: Engraved 22200944, sticker 10302917
Any help would be appreciated.
Old Jul 16, 2012 | 06:02 PM
Pfadt Racing's Avatar
Pfadt Racing
The front is definitely a C5Z front spring. Unfortunately I can't identify the rear spring number by either the engraved or sticker number.
Old Jul 17, 2012 | 09:16 AM
el es tu's Avatar
el es tu
Front is c5z 526lb
http://www.corvetterecycling.com/Pro...Code=25962573+
rear is z51 c6 645 lb
http://www.corvetterecycling.com/product_p/22200944.htm
Old Jul 17, 2012 | 10:03 AM
Shifter6's Avatar
Shifter6
Originally Posted by el es tu
Great info! Thanks
Is the C5Z front spring the same as a C6 Z51?
Old Jul 17, 2012 | 11:59 AM
el es tu's Avatar
el es tu
Same 526lb, but not sure if it will fit - there are threads where people ask about it, but no 100% clear answers.
However I do know that the rear c5 and c6 aren't interchangeable,
Old Jul 17, 2012 | 12:26 PM
Shifter6's Avatar
Shifter6
Here is a couple of pics. I am not sure what a front C5Z spring looks like...
Old Jul 18, 2012 | 09:13 AM
Shifter6's Avatar
Shifter6
OK I figured it out. Both numbers have been superceded by GM.
The front spring number is for FE3 sport suspension manual and automatic transmission from 1997-2012.
http://www.gmpartsdistributor.com/pa...ow=1&maxRow=10
The rear spring number is for FE3 sport suspension manual and automatic transmission from 2005-2012.
To C6 Leaf Spring Identification
