problems starting!????
Old Jul 26, 2012 | 03:32 PM
mwawrzyniak's Avatar
mwawrzyniak
5th Gear
Default problems starting!????
So its not my battery, starter, or alternator. what else can it be that i cant start my car??
Old Jul 26, 2012 | 04:46 PM
taken19's Avatar
taken19
Track Junky
Is it turning over or just clicking?
Need more details with respect what does and doesn't work before you will get useful help.
Old Jul 26, 2012 | 04:55 PM
1fastbob's Avatar
1fastbob
2005? Steering column lock? Battery cable where it attaches to the starter solenoid? Need more info.
Old Jul 26, 2012 | 05:15 PM
C7&7's Avatar
C7&7
If its turning over and dieing then replace the fuel pump relay.
Does the car complain of steering column lock on the DIC?
How do you know it's not the battery? Did you replace it or get it tested?
Old Jul 26, 2012 | 05:48 PM
mwawrzyniak
5th Gear
it is just clicking. the guages turn, accessory mode turns on after it doesnt start.
Old Jul 26, 2012 | 05:51 PM
mwawrzyniak
5th Gear
i got the battery tested. they said my battery alternator and starter were ok.
Old Jul 26, 2012 | 05:53 PM
C7&7's Avatar
C7&7
If the car does not give a steering column lock message when you start it then it's the battery.
Quick test of the steering column lock would be to disconnect the positive side of the battery and count to 10. Then reconnect it and try to start the car. If it starts its probably the steering column lock. If it doesnt then it's probably the battery, and you should replace it.
I had an 05 do weird things like this to me, and I ended up just keeping it on a tender when it wasn't driven and replacing the battery. Battery just tested doesnt mean much in these cars, especially the 05.
Old Jul 26, 2012 | 05:54 PM
taken19's Avatar
taken19
Track Junky
Yes, the 05 model is certainly a finicky beast! Hook up a different battery just to see if it works. You may be surprised...
Old Jul 26, 2012 | 05:59 PM
mwawrzyniak
5th Gear
thanks going to the garage now
Old Jul 26, 2012 | 06:59 PM
Jhaintz1980's Avatar
Jhaintz1980
After you get it started I would recommend you getting the column lock eliminator bypass kit from corvettes of Houston. I just installed mine the other day after having my car in the shop for 3 weeks with them replacing the column lock module. Then you will never have to worry about starting issues unless your battery goes bad.
Old Jul 26, 2012 | 07:48 PM
VET4LES's Avatar
VET4LES
Keep us posted. Sure sounds like the battery. How was it tested? The only way to test a battery is by load testing it.
Old Jul 26, 2012 | 07:49 PM
kmthor00's Avatar
kmthor00
Can't be original battery right?
Old Jul 27, 2012 | 01:33 PM
taken19's Avatar
taken19
Track Junky
Any update?
Old Jul 27, 2012 | 03:08 PM
mwawrzyniak
5th Gear
purchasing the battery today and will find ot. not sure if it was the original bought it used 3 years ago.
Old Jul 27, 2012 | 10:52 PM
taken19's Avatar
taken19
Track Junky
So, was it the battery?
Old Jul 30, 2012 | 01:25 PM
C7&7's Avatar
C7&7
Had to be.....Don't leave us hanging.
To problems starting!????
