What are your Grand Sport Dyno #s? LS3 Dry-sump only.
Old 08-16-2012, 09:07 PM
PagePilot
Support Corvetteforum!
PagePilot's Avatar
Default Base Run Prior to Tune.
ADVBedouin,
DYNO Sheet,
The base run prior to tune, was 386.33 RW HP @ Approx. 5800> RPM, and 386.67 RW TRQ @ Approx. 4500> RPM.
After tune, was 400.84 RW HP @ Approx. 5800> RPM, and 400.38 RW TRQ @ Approx. 4500> RPM.
A/F tune was approx. 12.8 starting at approx 2250 RPM > 6400 RPM.
Respectfully,
David
Old 08-19-2012, 11:53 AM
JoesC5
JoesC5's Avatar
Received 1,700 Likes on 1,214 Posts
Originally Posted by ELP_JC
I never came off as a 'tough guy', and didn't call you liar. But in your quest to win an argument, now you come up with 'nodular cast iron', which is a VERY different material than cast iron. It's like adding 'wo' to 'man, and then you have a woman, which is the complete opposite. Ductile cast iron is MUCH closer to steel than cast iron, so it's commonly referred as steel; THAT was my argument. Cast iron is what engine blocks are usually made of, not crankshafts. That was all. You win. One more to the ignore list (wanted to do it a while back). Have a nice life.
There are different types/grades of cast iron just as there are different types/grades of steel. You are the one that made the comment that all cranks are made of steel. Then you become a smart *** about it when it is pointed out that Corvette cranks are also made of cast iron. Cast iron is cast iron, no matter if it's grey iron , nodular iron or compacted graphite iron. Just because nodular cast iron is stronger then grey cast iron, does not make it steel.
Old 08-19-2012, 12:12 PM
AduB794
AduB794's Avatar
Pm's!! This is a dyno number thread, not a crank material thread.
Quick Reply: What are your Grand Sport Dyno #s? LS3 Dry-sump only.
