Service abs system light
Old Aug 9, 2012 | 08:47 PM
lockman's Avatar
lockman
Default Service abs system light
Well I just started getting a service abs system light what should I look at to try and fix this I haven't read codes yet as I'm in fl and the car is in va still but I'll be home sat and wanted to know what I should look at I'll also read codes but just thought I would ask some help before I get home thank you
Old Aug 12, 2012 | 09:54 AM
HKILP7M8's Avatar
HKILP7M8
I'm getting that in conjunction with check brakes, dealer tells me I need a new master cylinder and booster.
Old Aug 12, 2012 | 03:29 PM
lockman's Avatar
lockman
Yea mine shows up randomly I'm going to try and bleed the breaks and see if that helps it
Old Aug 25, 2012 | 03:07 PM
HKILP7M8's Avatar
HKILP7M8
I wound up having to replace the master cylinder and booster, close to $800.00.
To Service abs system light
