Help reduced power.!!!!still
Old Aug 17, 2012 | 03:18 PM
franklc's Avatar
franklc
ttt
Old Aug 17, 2012 | 03:58 PM
RamAir972003's Avatar
RamAir972003
Default Heres the link.
http://www.gearchatter.com/viewtopic11755.php
Old Aug 17, 2012 | 04:41 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by franklc
Thanks , anthony will the tps % change when i let off the peddle, i know it should fall but when i let off it drops to about 8% and just a few seconds jumps up to 20% by itself is this normal. But when i press it it jumps back down then goes up , it only goes to about 75-80% before it jumps down to around 30% when the reduce power comes on. So what should map be reading
Depends...yes they can move around a bit.
Depending on what it has programmed in for start up air flow, idle air...
The C6's do not show anything more than 80-88% WOT. Not sure why but they never go 100%.
Idle running they can be around 6-11% depending on the tune and setup of the car. Start up, engine off they can be 15-22% again depending on setup.
TPS should move with your foot. So as you give it gas it should go up, and vice versa.
Old Aug 20, 2012 | 04:01 PM
franklc's Avatar
franklc
ok guys i think ive found the problem . my tps sensor 1 voltage that is supposed to drop from 4v . ok as i press the pedal it starts falling and as i slowly press on down when it reaches about 2v it starts jumping erraticly to 3v,0v,2v just all around. and then the reduce kicks in.... no other volts or % does this there all smooth. SO GUY WHAT WOULD YOU THINK????????
Old Aug 21, 2012 | 12:50 PM
franklc's Avatar
franklc
ttt
Old Aug 27, 2012 | 01:06 PM
franklc's Avatar
franklc
well think i about have the electrical probles fixed, finally borrowed another tb, after doing alot of testing and checking it looks as if i have to have another tb. after putting on my friends tb i didnt get the reduced power, so now im going to by anotherone maybe it will last. thanks for all the help
