--Important read-- Engine Oil Tech
Old Nov 10, 2012 | 05:15 PM
  #41
Justasheet's Avatar
Justasheet
Originally Posted by Subdriver
Sharing here as I caught this thread late.
Concur with both the thoughts above that higher ZDDP is needed in some applications and that modern oils have better fluid film strength than historic oil (though synthetics have been around for decades now).
But, you can get both:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
This oil was designed for flat tappet cam engine which require higher ZDDP than allowed by the API for current spec oils (800 ppm max phosphorus). Though desiged for flat tappet cam engines, the good basestock and extra ZDDP helps in high demand applications such as those discussed in this thread. The Z-ROD is very similar to AMSOIL's Dominator Racing 10w30 I use at the track, but it has enough detergents for 3-5k miles (or one year whichever first) whereas I change the race oil about every 500 miles.
Jeff was concerned about the cats. My thoughts:
I personally think the concern about phosphorus damaging cats is a little overblown. The cats don't actually get "damaged", rather the catalytic conversion they are supposed to do is inhibited. Essentially the phosphorus "poisons" the cats. The EPA mandates emissions systems last 120k plus miles these days, so the current limit of 800 ppm impacts the cats over significantly more miles than most Vette owners will ever see. Another consideration is that the volatility of oils varies. Oils with low volatility (like AMSOIL) will lose less oil through the exhaust, thus less phosphorus will get carried to the cats. API SN spec allows up to 15% loss in a 1 hour test per ASTM D5800. In a 2008 test, AMSOIL's API spec 10w30 had 5.7% loss, well below the limit (Mobil 1 Extended Peformance 8.2% and Chevron Supreme 14.75% as comparison points from the same test). Additionally, though cats are not cheap, they are less expensive than engines. I'd use the appropriate oil for the engine and deal with the cats when (if) they didn't meet a state mandated test. Personally, if I had a modded street/track car, I'd use the Z-ROD. For strictly track, I use the Dominator Racing 10w30. Both independent of whether I had cats or not (and noting that SCCA T1 required cats until a few years ago).
I put the Z Rod Amsoil in today. Thanks Brad. I'm running Amsoil in the motor and an Amsoil air filter in my Vararam now because of your assistance. Thanks
Jeff
Old Nov 11, 2012 | 09:18 AM
  #42
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Jeff
My pleasure!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 11, 2012 | 12:46 PM
  #43
victorf's Avatar
victorf
Redline motor oil is available at Amazon for $10.71/Q with free Super Saver Shipping even to Hawaii!!
Old Nov 11, 2012 | 10:39 PM
  #44
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The thread is 8 years old, so the information may not be current anymore.
Old Nov 11, 2012 | 11:39 PM
  #45
Redrocket1045's Avatar
Redrocket1045
Originally Posted by NospdLimit
Why would you want 0w anything in the LS engine?
FWIW - Not that our car engines are built to NASCAR specs, but they do run a 0W engine oil on most races and are thermoststically controlled.
Old Nov 12, 2012 | 12:26 AM
  #46
sallen619's Avatar
sallen619
You are correct...
I think the belief is most of the the Mobil line up is PAO based with added Esters and the 0W-40 has some POE in its base. Key word is "base"...I can't back this up...this is just my opinion based on the limited searches I've done.
On the Mobil website they tell you that Ester is in their Oil...but they will not say that it is an Ester Oil (which agrees with what Anthony is saying).
The botom line is most of the current oil out there is designed for stock engines driven at the speed limit and rarely seeing high revs.
If you drive hard, drag race, autocross, hpde race or have modified your engine internally, look for a higher performance oil to help protect your engine.
The cam I purchased from Schneider Racing came with an "Extreme Pressure Cam Lube"...its thick like a paste...solid at room temp.
Old Nov 12, 2012 | 12:49 AM
  #47
07MontRedcp's Avatar
07MontRedcp
Originally Posted by sallen619
You are correct...
Here is the link to that very vague answer that Mobil provided when the were pressed for a specific response:
http://www.mobiloil.com/USA-English/...Ester_Oil.aspx
I ask them if Mobil 0W-40 was a group 5 Ester based oil and they responded: "Mobil does not discuss motor oil formulation information as it is considered proprietary and not available to the general public.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL"
-MJ
BJK
Old Nov 12, 2012 | 08:00 AM
  #48
el es tu's Avatar
el es tu
Originally Posted by glenB
Animal based .... like dinosaurs ..
reminded me of this:
Old Nov 12, 2012 | 09:00 AM
  #49
C66 Racing's Avatar
C66 Racing
Post 222 (page 12) of this early 2012 thread would indicate otherwise:
http://forums.corvetteforum.com/c6-c...g-hype-19.html
You'd have to read the first 12 pages to get the background, but the summary is that Lubrecon who worked in the industry had been claiming Mobil 1 to be PAO (Group IV) basestock until post 222.
Old Nov 12, 2012 | 12:34 PM
  #50
keevo54's Avatar
keevo54
so whats a good street oil for a cammed car?
Was thinking of going with AMSOlL. The shop that built my motor recommended I run 20w-50. Was looking at this one AMSOIL Z-ROD 20W-50 Synthetic Motor Oil (ZRF)
Old Nov 12, 2012 | 03:50 PM
  #51
C66 Racing's Avatar
C66 Racing
If they recommend a 50 grade, then the Z-ROD 20w50 is a good choice for a cammed street car in my opinion - has good amounts of ZDDP and enough detergents for 3-5k mile oil change intervals (or one year whichever first) whereas the similar racing oil I use is changed every 500 miles in my car.
That said, 50 grade seems high - did they mod the bearings? If the bearings are stock, I'd personally consider the Z-ROD 10w30 which has a viscosity more suited to the stock bearing clearances. FYI, I use 10w30 at the track in my stock internal LS6 (but run with modified PCU, headers, no cats/ mufflers and with higher than stock rev limit).
Either way, more than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
Old Nov 12, 2012 | 05:54 PM
  #52
JasonS5555's Avatar
JasonS5555
Hey guys,
Great read. I always enjoy a good oil debate
One question that has occurred to me. How many of you with a Z06 or GS are seeing really cool oil temps in the winter time with street driving? Wouldn't that have an effect on which winter oil weight you select? I'm seeing ~140-~160 on the highway.
Has anyone seen any issues with the oil running really "cold" all winter?
Thoughts?
Jason
Old Nov 12, 2012 | 11:06 PM
  #53
sallen619's Avatar
sallen619
Thanks for the link...
I believe that the Mobil 0W-40 is the "old school" formula (ie. better quality. I believe that the rest of the line up probably is the cheper base stock.
With that said, I will be looking for a higher performance oil the the factory fill.
Old Nov 13, 2012 | 02:32 AM
  #54
Rebel 1's Avatar
Rebel 1
I run Mobil 1 0w-40 in our C6 and C5. I am very satisfied with it. This formula has all the protection i want and it is $6.47 per quart at walmart. Excellent oil.
I have several C5 and C6 friends. One C5 has 244,000 miles on it and he has always used Mobil1 5w-30 with no problems. Another car has 151,000 miles on it and he has only used Mobil1 5w-30.
I have always liked Mobil1. Won't use anything else.
Old Nov 13, 2012 | 07:27 AM
  #55
1fastbob's Avatar
1fastbob
I also run Mobil 1 0w40 and have no issues and if I need some more I can run to Walmart or O'reillys and buy it.
Old Nov 13, 2012 | 09:07 AM
  #56
Justasheet's Avatar
Justasheet
Do you guys race your cars?
Old Nov 13, 2012 | 04:47 PM
  #57
Rebel 1's Avatar
Rebel 1
Raced more than i can keep count of, mine and building engines for others.
To --Important read-- Engine Oil Tech
Old Nov 13, 2012 | 04:54 PM
  #58
Rebel 1's Avatar
Rebel 1
I don't buy oil not available on the shelves.
  #59
Justasheet's Avatar
Justasheet
That's cool. I was running Mobil 1 but it seems that a higher quality oil is needed for those higher rpm's. It can't hurt to try.
Jeff
Old Nov 13, 2012 | 05:02 PM
  #60
Rebel 1's Avatar
Rebel 1
Jeff
To each his own. Whatever it's worth, i have built and do build engines that turn 7,000-8,000 rpm(depending on the engine and its build) with no problem.
Bob
