Corbeau A4 Install
Old Nov 29, 2012 | 08:08 PM
timd38's Avatar
timd38
Default Corbeau A4 Install
Has anyone installed these seats in a 2006 with the cheap seats?
if so, was it a big deal and what did you need to buy to go with the seats.
Thanks!
Old Nov 29, 2012 | 09:50 PM
acrc6's Avatar
acrc6
Thanks!
I installed these in my 07 1LT. The only thing I needed to buy were the seat position sensors from Dan at vetteworks. just let him know what type of stock seats you have and he will let you know what you need to get; great vendor.
You will need your seat harnesses and the passenger pressure sensor bladder from underneath the passenger seat. The easiest thing to do for the passing bladder is just roll it up and zip tie really tight and put it under or behind the new seat. This will trick the ECU into thinking that someone is in the seat and will leave the airbag light off on your dash.
Old Nov 30, 2012 | 06:01 AM
timd38's Avatar
timd38
Thanks! I bought my harness bar and mounts from them.
To Corbeau A4 Install
