Light cleaning
Old Jan 1, 2013 | 02:02 PM
JAKE-SON's Avatar
JAKE-SON
Default Light cleaning
Have tried three different headlight restore kits to no luck. Seems like they are very very fine scratches. Seems like some areas are beginning to clear up, but it took hours for them to begin clearing. Is there any product out there specifically made to fix this?
Ryan M.
Old Jan 1, 2013 | 03:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Is all of the problem on the outside, or is some on the inside and some maybe even in the plastic itself?
Those are good pics, but still hard to tell.
If you give up, we have at least 1 CF member (RLSebring) who will install new lenses for you, not actually cheap but a whole lot cheaper than buying a complete headlight assembly.
Old Jan 1, 2013 | 04:20 PM
JAKE-SON's Avatar
JAKE-SON
Its all outside. If you look closely, you can see some clear spots that took a lot of buffing to do
Old Jan 1, 2013 | 04:54 PM
speedraider's Avatar
speedraider
start sanding
Old Jan 1, 2013 | 07:36 PM
JAKE-SON's Avatar
JAKE-SON
Originally Posted by speedraider
start sanding
Lol. Had a bad feeling that i just need to stay out there on it
Old Jan 1, 2013 | 09:48 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Several threads on here about sanding then clear coating. Weight the effort, time and cost vs just replacing the lens.
Old Jan 1, 2013 | 10:32 PM
JAKE-SON's Avatar
JAKE-SON
Thanks ill look into it
Old Jan 1, 2013 | 10:46 PM
HOXXOH's Avatar
HOXXOH
Try whitening toothpaste. It has nearly the right amount of abrasive to blend out the scratches without putting more in. Follow up with a regular toothpaste to finish. Do not use a power buffer.
Oh yeah! It still takes a six pack of elbow grease.
Old Jan 2, 2013 | 01:43 PM
victorf's Avatar
victorf
Like everything else, if you choose to repolish, use only dedicated components.
Member RLSebring is the subject matter expert on light lens. Better to consult with him. Unless you want to tackle the replacement yourself.
Any effort to polish the oem lens will positively/permanently removed the UV protective filmed exterior, which is not possible to restore with after market gimmicks at this point in time.
Old Jan 2, 2013 | 09:13 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: How many miles do you have on your Vett? Do you wipe them off every now and then? Could this have been preventable? I am just asking because my 07 Vette has over 145,000 miles on it and my head lights still look good. I do wipe them off evey few days with some Eagle 1 quick detailer.
Old Jan 2, 2013 | 09:56 PM
speedraider
145,000 miles ..WOW....WINNER WINNER CHICKEN DINNER
Old Jan 2, 2013 | 10:07 PM
Gering's Avatar
Gering
Tolero Apto Victum
Thanks, it has been a great DD.
Old Jan 2, 2013 | 10:17 PM
HOXXOH's Avatar
HOXXOH
I think you're seeing the same thing I see.
It appears the OP has already burned through the SR coating with high abrasives, which is why I suggested toothpaste to clean up the scratches with a milder compound. It's a lot harder to do with polycarbonate than acrylic.
To Light cleaning
