Using 89 octance fuel in base engine...
Old Jan 21, 2013 | 01:08 PM
South40's Avatar
South40
Default Using 89 octance fuel in base engine...
I know this has to be a well-discussed topic, but I didn't see it so... What are the trade-offs, potential hazards for using 89 octane [mid-grade] instead of premium in the base, 430 hp (for 2013) engine? Since I'm not concerned about getting the full 430 hp out of it, can I run 89 fuel in it w/o issues? The manual says I can but I'd rather hear answers from the real-life owners out there. Thanks.
Old Jan 21, 2013 | 02:49 PM
mracer14's Avatar
mracer14
Default Gas
The manual also suggest that you run 93 oct. If you can afford a 'Corvette' you can afford 93.
Old Jan 21, 2013 | 05:50 PM
ParisTNDude's Avatar
ParisTNDude
The compression ratio is the problem with running lower octane fuel. The computer will adjust timing to some degree to allow lesser octane fuel, but...but not that much. I know on my C5 that running lower octane fuel made for huge timing "ping" and scared the heck out of me. I was in Europe and could not find a station with higher octane and was nearly out of fuel.
The difference in cost of a tank of 93 compared to 89 couldn't be much more than $4.00. Why would you risk serious engine damage for that little bit of money? Just my opinion.
Old Jan 21, 2013 | 07:53 PM
jpee's Avatar
jpee
Why the hell would someone/anyone put in 89 just to save ..(like you said) about $4.00 on a tank of gas...
He would be better off getting a Cobalt 4 cyl. they are designed to run on 89 !!!
Old Jan 21, 2013 | 09:06 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
With 89 instead of 91/93:
You lose a bit of power.
You lose a bit of MPG, which partly negates the cost savings.
You are betting your engine that the knock retard system will work properly when you get on the throttle. Failures are pretty rare, but that's a bet I prefer not to make.
If 89, or even 87; is the only gas available, then I use it and don't worry much. But if I have a choice, I go for 91/93.
Old Jan 22, 2013 | 08:22 AM
South40's Avatar
South40
Default Octane...
At issue is what's available at times. Sometimes, the highest grade at a station is 91 or even 89. I don't want to hurt my lil red machine but I suspect, from time to time, it'll have to get by with 2% instead of whole milk...
My wife's Miata absolutely complains with anything less than 93; hopefully my car is more forgiving.
Yesterday I took my machine out for a curvy drive Seneca, SC to Highlands, NC to Cashiers, NC and then home - wonderful day and great tryout for my paddle shift auto - works fantastically! It's probably faster to respond to gear changes than I'd be shifting the manual w/o some serious practice. {I've been using manuals for 54 years so I'm good with them but each manual has it's own personality.} If you're contemplating the paddle shift auto, test drive one and check it out - you may become a convert.
To Using 89 octance fuel in base engine...
